Ah cool, no I didn't thanks!
E-flite Carbon-Z T-28 BNF Basic 1981mm (78") Wingspan
Just click on the edit / (pencil icon) down in the lower right corner of the post your concerned with.
You will then see a cancel, delete, preview and save square buttons in the bottom right. Select the delete. ;)Warbird Charlie
Well this plane is gonna spoil me to no end... I've never had an easier plane to fly! Thank you Ole Timer for those setting, those were spot on for me, didn't have to change a thing. I won't wanna fly any other plane again! It was absolutely amazing how smooth it was, hands off and everything! Thanks again! I'm freaking hooked!
Originally posted by Bob Symes View Post
I will check on the left retract. After fitting the struts I cycled them 8 to 10 times without a problem.
once I get a replacement retract(out of stock from my Aussie supplier) I will make sure the strut pin is not too deep.
much appreciated for the info TiredIronGRB
thanks
Bob
cycled the retracts approx 25 times with no issues. Time to redo CG with new Graphene 5000 45c batteries and maiden.
thanks again TiredIronGRB for the info on the gear mods.
Regards
Bob
I just have a problem with my right main gear, if I am in the air the pressure of the air pressing it backwards will cause it to stall on the way up and hang there, the only way I could get it to go all the way up was to slow my plane down to near stall speed. Any ideas on what I can do with it?
Originally posted by rifleman_btx View PostWhere can I find a cowl for this thing? Every place I look is sold out!:Angry::blueangry
