E-flite Carbon-Z T-28 BNF Basic 1981mm (78") Wingspan
Glad I went mining, you answered my question I was gonna ask over on the P-47 thread about strut length to determine if it would work on this CZ T-28.:ok_hand:I used struts for a FMS 1500mm P-47 and used the stock T-28 wheels but had to take the tires off and sand the sides of the wheels down so they would fit on the axle, I used a sheet of 280 wet/dry laying on a smooth flat surface and just sanded down the hub till it was flush with the wheel.
I didn't use the lower gear door cover (they grab grass anyway) but I used the top one and just made new wires to connect it to the strut. The pins that go in the retract need the flats re-cut to center the strut/wheel assembly. I have a Freewing 80mm A-10 nose gear I plan to use as well.
Now I gotta know, did you do the A-10 nose gear and if so were ya happy with the mod.
Re front strut I've been looking at this:
https://www.motionrc.eu/collections/...-tire-b#qa-tab
According to Q&A dimensions are:
length from top of strut to end of tire 183mm (extended)
length from top of strut to end of tire about 160mm (compressed)
Tire size 70mm
I've no idea if this will fit, yet, so when I get a minute spare I'm going to take my front retract out and measure its dimensions and check to see if the replacement strut will bolt onto the same fitting. More another day...Comment
I've measured the original gear now and this Freewing A10 replacement should fit perfectly. It will need a connecting pin and they sell these separately:
https://www.motionrc.eu/products/fre...ing-pin#qa-tab
I'm also going to fit a 14 x 9 Master Airscrew 3 Blade Propeller to make it look more scale.
I'll confirm once it's all fitted up and working...Comment
Mikdys I was actually looking at the same thing yesterday after I ran across the stock A-10 nose strut in my spare parts stash. The pin will need to be longer than the stock A-10 pin, in order to use the stock T-28 steering arm. Other than that, it should work.
I haven't found anything that might work to replace the mains with yet.Comment
Thanks for the advice, I'll save a couple of dollars and make the pin instead. Have you any idea of the dimensions needed? I'm guessing it will need to be 5mm diameter and 60mm long maybe.Mikdys I was actually looking at the same thing yesterday after I ran across the stock A-10 nose strut in my spare parts stash. The pin will need to be longer than the stock A-10 pin, in order to use the stock T-28 steering arm. Other than that, it should work.
TwowingtjMikdys I was actually looking at the same thing yesterday after I ran across the stock A-10 nose strut in my spare parts stash. The pin will need to be longer than the stock A-10 pin, in order to use the stock T-28 steering arm. Other than that, it should work.
TJ.........TI said way back on post #22 that the FMS 1500 P-47 struts work.
The pins should be solid, the A-10 strut is drilled 12-13mm deep for the pin.
OV10 Have you changed struts on yours yet? Getting ready to paint both of our T-28s and considering doing the struts at the same time.Comment
Thanks - I understand now (the pin needs to extend 12-13mm beyond the steering arm)
I'm looking for a set of Razorback main oleo's and I still have the wrecked A-10 original nose oleo(not the upgrade trailing link one you guys are pondering on) to use.
That's my plan for change as soon as I get the mains and this stupid weather settles to let me get the bird out of the rollin hanger. :rolling_eyes:Warbird Charlie
Well after much work my T-28 has a new look. The grey yellow red China Lake scheme looks great in the air. My Friend J Price redid his in a Viet era camp and it looks awesome in the air. Both have a redone cockpit and sound cards. We are flying with a 3 blade 16x8 Master and it hauls butt around the field.5 PhotosComment
MANFRED Superb refinishes by both of you! How did you tint the canopy? Masked and painted with Tamiya Clear Green? Or is that trans cellophane? The edges look too sharp to be a Rit-Dye job.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Camp my Instagram @Alpha.MakesComment
Exactly Alpha, PActra green tint, masked and sprayed, my first attempt at tinting. I redid the cockpits on both the mask the dreaded gathering. Why is it manufacturers cannot pull a plastic mold of all interiors to avoid this unsightly blew. Surely all of us would pay a bit more for this feature. Thanks!!!
Has anyone had problem with the wing retract mount breaking. I was taxing on the runway and when I took off the right wing retract got hung up. Once on the ground I noticed the plate was broken and it allowed the retract to shift hitting the wing. I cannot find the plate I have to reorder a whole new right wing. I'm looking to expoy the mount or try to reinforce it with some wood. Any thoughts I'd appreciate.Comment
Those retracts seem to have to take a lot of abuse, especially if you operate from grass. There’s a lot of vibration as the plane rolls along the ground. My plate cracked in several places as well as the little plastic thing that attaches one end of the wire that holds the door. All repairs were improvised as parts are either non-existent or very costly. For the cracks in the plate, I squeezed glue (sometimes FoamTac, sometimes epoxy, depending on the location of the crack) in and under the crack and applied clear Gorilla tape over the crack and surrounding area for reinforcement. After several repairs, the retracts are quite sturdy now but I must admit that I grease the landings pretty much every time now, removing the cause of much of the damage that occurred when the plane was new.Has anyone had problem with the wing retract mount breaking. I was taxing on the runway and when I took off the right wing retract got hung up. Once on the ground I noticed the plate was broken and it allowed the retract to shift hitting the wing. I cannot find the plate I have to reorder a whole new right wing. I'm looking to expoy the mount or try to reinforce it with some wood. Any thoughts I'd appreciate.Comment
.png)
