Dornier DO335 Pfeil ("Arrow") 1724mm (67.8") Wingspan from Black Horse - Balsa Wood ARF - BHM1004-001
You asked, and we finally answered. It was important to us to update the covering to a matte finish with factory-printed weathering, as opposed to the glossy covering of the old Arrow. Along the way, we also worked with Black Horse to update some other internal aspects of the model to make it easier to assemble, configure, and operate.
The Dornier Do 335 Pfeil ("Arrow") was a German World War II heavy fighter built by the Dornier company. The two-seater trainer version was called Ameisenbär ("anteater"). The Pfeil's performance was much better than other twin-engine designs due to its unique push-pull configuration and the lower aerodynamic drag of the in-line alignment of the two engines. It was Nazi Germany's fastest piston-engined aircraft of World War II.
The model is scaled to approximately 1:8 scale and attention was paid to a true to original appearance and best flight characteristics. The model can also be operated using an electric power system.
Factory Weathered Printing The printing on this model has a realistic weathering complete with rivet and panel line detail that elevates the model to a whole new level of scale appeal. |
| Fiberglass Molded Cowl Single piece cowl is molded from fiberglass for the ultimate in rigidity. |
Gas or Electric Power You can choose between gas or electric to power your model depending on your preference. |
| Large Electronics Hatch A generously sized battery hatch allows easy access to internal electronics system, or a fuel tank in Gas Power installations. |
- All-new realistic multi-layer weathered printing
- High level of prefabrication right out of the box
- Lightweight, strong, laser cut balsa and plywood construction
- ~1/8 scale
- Panel lines and details printed directly onto the pre-applied, high quality covering
- Airfoiled tail surfaces
- Recessed hinges on all control surfaces
- Pre-drilled hinge mounting holes
- Heavy-duty pin hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed cockpit, pilot and interior included
- Fiberglass control horns with ball link connector
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly
- Fiberglass cowl and glass reinforced landing gear covers/pants
- Mounts for both electric and gas power options included
.png)
in using counter rotation for both. The Pheil used standard rotation prop(CW from pilot seat) on front and CCW prop on the rear using a standard CW engine.
Your over thinking it buddy.
