The motor s are still the same as the original 550 maph motors in the Atlantic harbor tug made by aqua craft And the fire boat and the fletcher class destroyer I ordered them on motioned
Official Discussion Thread: Bancroft 1/72 scale Fletcher WW2 Destroyer -RTR
For ballast u can also use bbs = gun ammo as ballast weights in the bow of the rc battle ship and the aircraft carrier Nimitz 1:200 scaleComment
eh ayie everyone, Top o zhe morn , it’s a finayie to drive my battleship since all the dry dock repairs have been completed I used a microlux competitor brand of dremel to fix the newly freshly painted plane launcher ttyl for now hope that I ave a very safe 4th of July holiday ttyl3 PhotosComment
I want to recreate the canvas that was sometimes placed over the railings on Fletchers. Around the railings above the Bridge and railings around the funnels. Can anyone suggest a material that would resemble this at 1/72 scale please. Thank youComment
Hi. The Bancroft Fletcher is my first RC ship. Just thought I would I ask you guys with experience what I could do just to ensure that I don't sink it somehow. I thought about adding some pool noodle foam to the front of the boat since there is quite a bit space up there. So, I cut up some long pieces of a pool noodle and saw just how much of it I could actually fit in the space available in front of the boat. Then I took those pieces out and placed them in a tub of water. I then attached an 8 pound weight to the foam but the foam could not support the weight of 8 pounds, which is the weight of my ship so far. The 8 pounds of weight just took my foam to the bottom of the tub. Any suggestions about this or any other thing I could do to make my first boating experience a success would be most appreciated. I know that your experience in these models will help me avoid some learning pitfalls so thanks again.Comment
Racer. I don't know about keeping it from sinking totally but I do know the Clubs that do RC ship combat often put a float with a recovery line attached on their ship. With the fiberglass hull these things are actually pretty hard to sink unless you really mess up the ballast or have a total fail on one of the 3 hull penetrations (rudder and shafts). One think you can do to keep it on the surface in such a fail is a watertight bulkhead forward comprising most of the Bow section. What you are looking to do is displace water in this case not necessarily support weight. It won't keep her neatly afloat but it may keep her on the surface for recovery.
A couple of things you can do to prevent sinking is some general maintenance. Grease for the stern tubes and rudder stock. (look through the forum here I know there is a conversation about it the PT boat thread I think had a rather involved discussion about it.) Do a water tight test before you send it out in the middle of the lake. (let it sit in the water for a few minutes then check inside for signs of leaks) Don't send it out in a lake with large waves due to weather or people driving jet skis or boats(the non RC kind) leaving wakes behind. Bring it back before the battery dies. Have a recovery boat that can push it to shore or a small boat of your own if the battery or electronics do die. DO NOT SWIM for it people have died doing that and some places banned rc boats due to it.
Hope this helps.Comment
well I finally bought the bb's and measured and weigh the bb's out to equal two pounds so i have finally nailed out the ballast problem so definitely will use bb's for all my Rc battleships, To, when can afford to purchase them but I'll be buying the Nimitz next year not sure when next year in tax time hopefully I can swing the purchase but ill post some pictures soon
brb soon
hi racer x bb's 2 lb. of bb's will equal the ballast evenly i have yet to try out the fletcher on a maiden voyage the container of bb's 17.99 +1.00 to wildlife and sales tax 1.35 grand total $20.34 that's how much i spent on bb's, if u have a digital bathroom scale just weigh out 2 lbs. of bb the bb's I used was daisy bb's ttyl
i finally got my Bancroft rc transmitter on Thursday and i finally also got it binned to the receiver thanks to every one at motion rc in cluding ozzi i thought i was going to have to call u but i figured it out thank you very much now i hope that some day i have good weather to run my fletcher so ttyl for now
I purchased the 72 scale Fletcher class destroyer and am having a fun time with it. I would like to finish some detail work on it by getting a decal sheet for hull numbers and letters for the ship's name. Does anyone have any information on where I may get them? If so, contact me. I have been to numerous sites but to no avail. Thanks, Chuck. chucky.pea@hotmail.com.Comment
I just purchased one also. I'm on a work trip, so I haven't unboxed it yet. I'm planning to set it up as one of the famous ships which recieved a Presidential unit citiation. Maybe the Uss Evans (fought off kamakazies and survived) or Uss Nicholas...few other possibilities. On another forum, some wrote this in regards to decals...they used a website called Callie Graphics. Here's a link. https://callie-graphics.com/
"Ask her for the ones she just sent me a few months ago. Casey Thrower. Just tell her the numbers you want. Such as:
Callie,
I need your expertise once again. I need the same scale as the first order I made for the sub in 1/72 scale. I need the following:
HULL Numbers 557
Same as hull draft mark except in the following:
0
9
8
7
6
5
Lastly the name JOHNSTON in the same size and font as Scorpion. I’ll send pics. Thanks.
Casey"Comment
I opened and assembled the Fletcher yesterday. The ship arrived in very good shape. Kudos to Motion RC and Fedex for packing and delivering it with care. Just one storage locker loose, easy to re-attach.
One issue...the white post of the rear 5 inch gun, when inserted, rubs against the shaft for the rudder servo. Anyone else have this issue, and what did you do for a fix?
Also I've looked to get a second battery but finding the exact match is challenging. It's not available on Motion RC's site. I've seen many with close specs, but not an exact match.
Which battery parameters should be exact and which can be close? the "c" number varies widely, for example. And the XT60 connector isn't common, although one can get an adapter.Comment
I think I've found a compatible battery. It comes without a connector though. 2800mAh 2S 7.4V ProLite X Rx LiPo Battery, from Thunder Power, thp-2800-2spxrx (chiefaircraft.com)
Here is same battery, direct from the manufacturer WITH the xt60 connector. Thunder Power RC TP2800-2SPXRX – Thunderpowerrc.comComment
My Fletcher arrived last week and now is on display here at BSI. This model is a life long dream come true for me. I'm an aircraft guy, but a large detailed warship has always impressed me the most. I feel that the actions of a few U.S. Navy destroyers did more to win WWII than the combined effect of the battleships Iowa, New Jersey and Missouri. The Fletcher arrived looking even better than the photos I've seen. I had plans to do some repainting and weathering, but I canceled those today. The model just looks too good the way it comes. I'm just going to add the number 557 to the hull to honor the crew of the USS Johnston. Just thinking about their heroic actions in the Battle of Leyte Gulf brings tears to my eyes, every time.
I can't image that the $999 price will last much longer. It is worth at least three times that much.
