Bancroft PT-596 Patrol Boat - RTR
  • Hozer
    • Dec 2022
    • 11
    Originally posted by Hozer
    I'm already having electrical problems with my 3 week old PT built in 4-2022. The first run went well with the stock 2800 2 cell battery with just warm ECS and motors. I ran it again this week end and barely got the PT back to shore. .The stock ECS was warmer and the motors were hot to the touch. Now the motors wouldn't run and it has no steering. The stock ECS has a blinking red light and when I turn the transmitter on first and then the boat power button it beeps twice but not the third time. Is the stock ECS burned out?
    Update- I found the problem, a loose connection on the steering servo to the Rx. I pushed it in all the way and everything works fine. ESC and motors are cool once again with the 2800 2 cells in parallel with scale speeds for 30 minutes.
      • 5415
      So why was the motor and ESC getting hot? Steering wouldn't cause that.
      • Hozer
        • Dec 2022
        • 11
        I have no idea. I need to run the PT again soon.
        • Hozer
          • Dec 2022
          • 11
          So, I ran my PT again with the twin 2800 2 cell Admiral batteries in parallel and everything (ESC and 3 motors) remained comfortably warm to the touch and not HOT. I got a 35 minute run at half to full throttle at scale speeds. Every thing worked with no issues.
          • Gigg
            • Feb 2024
            • 18
            I am considering buying this pt boat. I have read the entire posts. There has been nothing added as of late. My question have the issues mentioned in the above posts been resolved? I am not great hands on fixer so i really would like it to be mostly RTR. Thanks
            • Gigg
              • Feb 2024
              • 18
              Well i just received my pt boat talking to motion rc they said all the issues have been resolved ..i just noticed the build date is 4-22 should i be worried? please some one respond this has been a dead forum as of late.
              • Brandon Moon
                Fly, Enjoy, Have fun!!!!
                • Oct 2013
                • 335
                Awesome boat!!! had her on the water for the fist time today
                Brandon Moon
                • jhansen1440@gmail.com
                  • Mar 2025
                  Hi, does the pt boat have reverse?
                    • 4869
                    JH,
                    Welcome to Hobby Squawk, glad to have you onboard.
                    I have attached the Support PDF for the ESC.
                    In that PDF, the instructions discuss the 'boat mode' and in that portion there is a set up for forward, reverse, and brake.
                    This is done by inserting the short circuit pins in different positions on the ESC.
                    By the looks of this instruction, the ESC has reverse.
                    By the way, I would advise that you change you User Name to something other than your email address.
                    This is only for your security protection, just a thought.
                    You can contact Aros who is our resident IT guru and all around great guy, through a Private Message for an assist in changing your user name.
                    Best of luck and the Bancroft PT Boat is a great loking model.
                    Best, LB
