Upgrade Paths, Explained
  • canklebreaker
    • Feb 2021
    • 55
    Where can I find the main shaft bearing collar upgrade parts for the Abrams? I tried googling them but may not be looking for the right thing?
    • Rubicon99
      • 3316
      Aliexpress.com it a Chinese web site but safe to buy from. It’s kinda like their Amazon.
      • canklebreaker
        • Feb 2021
        • 55
        Cool, I'm familiar with aliexpress. Is it this item: https://www.aliexpress.com/item/3227...rchweb201603_?
        • Rubicon99
          • 3316
          Nope!
          Look up Heng Long Abrams parts. You are looking for bearings not a drive shaft. Although that drive shaft is also a great upgrade to the stock gearbox. I run them on most of my stock gearbox tanks.
          • canklebreaker
            • Feb 2021
            • 55
            lol think I found it...https://www.aliexpress.com/item/3288...archweb201603_
            Thats good to know regarding the drive shaft, I'll pick that up too. Its a shame there aren't any state side vendors.
            • Rubicon99
              • 3316
              Yep those are the right ones.
              • Chrislaf
                • Jan 2021
                • 19
                • Bristol, Connecticut USA
                Quick question are metal drive wheels, idler wheels and tracks compatible between the Challenger 2 and Abrams ? Thanks in advance
                • Rubicon99
                  • 3316
                  Only the sprockets are compatible but you must run the corresponding track with those sprockets. Abrams track with Abrams sprockets and vise versa.
                  • Chrislaf
                    • Jan 2021
                    • 19
                    Thanks again bro you've always got the answers I need. I bought a challenger 2 with metal gearbox but plastic everywhere else and also bought an Abrams with metal tracks and wheels. I also bought metal tracks with rubber pads with corresponding drive and idler wheels for the Abrams that I now wanna put on the challenger
                    • Rubicon99
                      • 3316
                      You will need to length the Abrams tracks by a few links. It is just a little shorter then the Challenger tracks if you want to swap them. It super easy to do.
                      • Chrislaf
                        • Jan 2021
                        • 19
                        Sweet !!!! Oh 1 more question if ya dont mind ? I picked up taigen JS-2 and was thinking about putting a KV-2 turret on it. It looks to be the same size but is it ?
                        • Rubicon99
                          • 3316
                          Depends. There usually is a bit more involved then just swapping turrets.
                          • Chrislaf
                            • Jan 2021
                            • 19
                            Oh ok I thought if it was the same size I could just pop it on and plug it in. What other steps are there usually ?
                            • Chrislaf
                              • Jan 2021
                              • 19
                              Ok I've been looking all over the web trying to find a set of bump stops for my taigen JS-2 and I can't find them anywhere. If anyone knows where I can pick up a set I'd greatly appreciate it. Thank you
                              • UltraVargen
                                Dutchie
                                • 266
                                • The Netherlands
                                Today I got my 6.1 MFU in, and noticed Heng Long opted to use a "dean" style plug for the power cable. An odd choice since the batteries they use have a Tamiya plug.
                                As I'm basically a noob when it comes to electronics: Why did HL switch to a different style plug? And what is best practice to adapt? I already have a spare Tamiya power cable with no plug attached to one end. Thinking of buying a separate female dean socket to create an adapter cable.
                                • Chrislaf
                                  • Jan 2021
                                  • 19
                                  In my opinion Dean's connectors are way better than tamiya's. I use them in all my rc cars, trucks and tanks. I've had tamiya plugs meltdown in the past that's why I never use them.
                                  • canklebreaker
                                    • Feb 2021
                                    • 55
                                    Agreed, deans is superior in my experience. I use them in my airsoft guns.
                                    • Chrislaf
                                      • Jan 2021
                                      • 19
                                      Love the name canklebreaker
                                      • Rubicon99
                                        • 3316
                                        They switch to Deans because the 6.1 has a higher amp and voltage rating and Tamiya plugs do not do well with high amp and voltages. Tamiya plugs are good to about 9 volts and 15 amps after that they get really hot and can melt with prolonged high voltage and amp draws. The 6.1 is meant to handle 3 cell Lipos (11-12v) and larger motors when combined can easily draw up to 20 amps = very hot.
                                        Trust me the Tamiya plugs would melt and most likely burn with 12v and 20 amps flowing through them for anything much over a minute or two of use.
                                        • canklebreaker
                                          • Feb 2021
                                          • 55
