Discussion Thread: Heng Long 1/16 Scale "Panther G" German WW2 Tank
I got the turret working by connecting the turret motor to the CN3. Some how it got messed up but worked before? The right motor is turning but the shaft connecting to the front wheel does NOT turn. Do I need to remove the tracks and the front gear? DaiComment
I spoke to Toucan and the right gear box is damaged. They will send replacement but I would like to upgrade with after market parts so I can see a difference. How about this one ? Thanks Dai
https://www.ebay.com/itm/Steel-3-1-G...97.m4902.l9144
That is a very slow gearbox “5:1” ratio. Stock HL gearboxes are “3:1”. It is mostly used in tanks to represent heavy slow speed handling characteristics. It is smooth running but can be more noisy then stock.I spoke to Toucan and the right gear box is damaged. They will send replacement but I would like to upgrade with after market parts so I can see a difference. How about this one ? Thanks Dai
Overall it have its place most in WWII tanks.
it is 3.1 as advertised. Thoughts? DaiComment
Hey Guys.
I hope you could help. I bought this tank for my dad.yesterday he called me and said that the tank doesn't work again. It's doesn't make anything just beeps sometimes. No lights and nothing is moving. Battery's are fully charged and battery's in the remote are new. Don't have more Infos. From my airplanes I thought the esc was not working but the tank doesn't do anything and the lights are off. So I think there is a bigger problem.
He lives 200km away from me. So I can't help him and check the tank.Comment
Contact the seller and reported the problem. I bought the first tank from Amazon and the last 5 from Toucan. Godfrey from Toucan is a very helpful guy and goes out of his way to make sure your complaints are addressed. You need to open the tank and see if the connection of the battery to the main board is disconnected. If you are into R/C tank, tinkering is a MUST. DaiHey Guys.
HL does make many red frame gear boxes called "ultimate gear box". However it does not make for the Panther G (3879). DaiComment
MRC support is first rate. Nowadays companies with better customer service win ! MRC will get it running in no time. Daidai phan Yeah if I had this tank next to me I would do that. Bought it motionrc and opened a ticket righ now. My Father didn't want to open the tank by himself.
Thx for your help.Comment
Yes they do. You have to know if your tank has a 49mm or 58/59mm shaft and is it a High/Low or Mid//Low motor mount. The “ultimate” are made in all these sizes.
I bought this to replace my defective gear box while waiting for replacement from China that could take 1.5 months as advised. It says 59 mm for the 3879 ( Panther G) but low high profile I do not know. If you can link me a product for my Panther G, I would appreciate it. Dai
https://www.ebay.com/itm/US-Stock-He...53.m2749.l2649
Low profile will work.I bought this to replace my defective gear box while waiting for replacement from China that could take 1.5 months as advised. It says 59 mm for the 3879 ( Panther G) but low high profile I do not know. If you can link me a product for my Panther G, I would appreciate it. DaiComment
