  • RichJohnson
    • 1300
    Nice staging and stowage with the scale rope.
    • SoCalBobS
      • 2761
      • Southern California
      So many teeth!
      • MrChef
        • Jan 2023
        • 517
        • New York, Not the city
        A little winter camo work to get me back into the swing. Just in time for the Battle of the Bulge Anniversary.
        • Panzermechaniker
          • Feb 2023
          • 144
          At some point in the future I will do a winter camo. I'll be bothering you for assistance in getting a result as nice as yours😊😊
          • Meter Rat
            • 507
            • Argyll and Bute, Scotland
            For some reason in post 1350 the pictures did appear.
            Took advantage of a day off work, and the wee bit of snow we had, to give the T72 a run out. ​
ID:	416296 Click image for larger version
ID:	416294 Click image for larger version
ID:	416295 ​​ ​​​ ​
            • MrChef
              • Jan 2023
              • 517
              Ohhhh yeah that looks great Meter Rat! Perfect amount of white stuff for the camo.
              • Rubicon99
                • 3318
                Another TongDe M60 ready for the battle field. This one is in a theme similar to US desert Merdec.
                Upgrades include a new TD "dual current drive" transmission, HL sprockets, Tamiya Abrams tracks, servo recoil/elevation, new more accurate M68 main gun( by RichJohnson Models N Stuff) and a HL7.1 controller system.
ID:	417413 Click image for larger version
ID:	417415 Click image for larger version
                • SoCalBobS
                  • 2761
                  M26 Pershing, 6th Tank Battalion, Korea 1951.
                  Tiger painting is all done. Still will be dirtying it up and adding external stores.
ID:	417524 Click image for larger version
ID:	417526 Click image for larger version
ID:	417525 Click image for larger version
                  • RichJohnson
                    • 1300
                    Very impressive Bob.
                      • 4869
                      SoCalBobS
                      Nicely done, Sir.
                      Best, LB
                      • DavidN
                        • May 2021
                        • 3204
                        • Los Angeles, CA
                        Awesome M26, Bob!
                        • SoCalBobS
                          • 2761
                          Thanks guys! Here's a short clip:
                          (I recommend watching on Youtube. Sometimes the resolution on the forum is coarser.)
                          • Rubicon99
                            • 3318
                            M60 video shoot out take photos.
ID:	418352 Click image for larger version
ID:	418353 Click image for larger version
ID:	418354 Click image for larger version
                            • MrChef
                              • Jan 2023
                              • 517
                              A little fun in the snow-
                              • MrChef
                                • Jan 2023
                                • 517
                                822 making here snowy debut
                                • SoCalBobS
                                  • 2761
                                  A smokin' hot Challenger!
                                  From little, my last project the M24 Chaffee to the largest, my Challenger II. I saw the muzzle smoke and flash unit on sale for $23, so I thought I'd give it a try.
                                  It took a few hours of fiddling, but it works. The unit has two parts, the motor and the smoke reservoir. They are fairly large, vertically as well as horizontally, so it needs a big turret to fit.
ID:	418429 Click image for larger version
ID:	418431 Click image for larger version
                                  • MrChef
                                    • Jan 2023
                                    • 517
                                    Love it Bob. I picked up one of those smoke/flash setups for my current tiger project too. Very cool. I'm a gun recoil/smoke/flash convert guy now.
                                    • jetfool
                                      • Nov 2022
                                      • 1360
                                      • Crawfordsville, Indiana
                                      Where did you purchase your muzzle smoke/ light? I have a 1/16 HL Tiger 1 Pro I'd like to add this too. Your tank looks great.
                                      Best Regards, Rex
                                      • SoCalBobS
                                        • 2761
                                        Best Regards, Rex
                                        You can find it on eBay. Toucan Hobby's retailers on there sells lots of Heng Long associated parts. Be aware, there is a wide price range for the same article. I've seen it sold for up to $70. Mine was $22.90 plus shipping.
                                        For anyone thinking of doing this, here's a quick runthrough.
                                        The kit consists of a motor/pump module, a heater/reservoir module, a control circuit, silicon tubing and a 3mm orange LED. There were no instructions with it, but there are numerous Youtube videos showing how. I viewed Toucan Hobbies' clip. One plug fits into CN5 on the Heng Long board, which is a switchable on/off circuit originally used for a wifi module. The other plugs into the LED1 socket. You will need to run both the LED and the silicon tube through the barrel. I found it difficult to thread both through, clearance was too tight. The Challenger barrel is very long, it might be possible to do it on a shorter barrel. Instead I used a brass tube of slightly smaller diameter and pushed the silicon tube onto it at the base.
                                        You will need to eviscerate the stock BB shooting mechanism. Cut off enough so that it is easy to thread the silicon tube and the LED wires through it. You'll also need to disable the airsoft circuit, either by placing a jumper on CN6 or via the controller; Buttons G and B.
                                        I managed to place the motor and heater in my turret, so that turret rotation doesn't kink up the tubing or wires. If your turret is smaller, you'll just have to find out your own satisfactory solution.
                                        As you can surmise, this will require a lot of disassembly, Just go slow and remember what goes where!
                                        • SoCalBobS
                                          • 2761
                                          Here's a very short clip of it in action:
