New "compatible" Heng Long 6.0 IR receiver test results
I worked with LegoDEI on developing the 6.0 HL version which also lead to further improvements with the Tamiya compatible versions. A lot of time went into testing them and they are capable of far more performance then advertised. Really glad to see your club moving over to them. LegoDEI is a really good guy and has a lot more cool things in development.Received a whole lot of receivers from LegoDEI today. The FRAG RC Tank Club has chosen to move to these exclusively as testing has shown them to be as good or better than the Tamiya unit. The 360 sunshade and 4 individual sensors create a better rounded battle experience, (we move our emitters to the the barrel and create a restrictor with a "pin-hole" aperture to narrow the shot.). Oftentimes, Tamiya's blind spots make battling less than equitable or fun. Lego DEI's receivers are also much lower profile and at a fraction of the cost.
Considering the size of the order, he was understanding of the process of collecting orders and money from the entire club. Once the order was in, I received the package in about a week. As the photos will attest, they were well packaged and are ready to distribute the members! Thanks LegoDEI!
We will be running a dozen or so of these this weekend at the San Diego battle day (Sun 7/19/20) and will be posting photos of the receivers in action.
Hit indication/counts are controlled by the 6.0 system not the IR receiver. The receiver just tells the MFU that it is seeing a signal. The MFU makes the determination if it will accept the signal as a hit.
All the LegoDEI receiver does is pick up the IR beam signals much better then the stock IR receiver. It functions regardless of the LEDs lighting up.
During testing I often used the LegoDEI receiver without the LEDs connected.Leave a comment:
I think he’s looking for hit “indication” not hits counted. I would think he needs the 2 extra wires and not the 3 wire for LED indication. Can the two extra wires be spliced into the power wires of the 3 wire and still have enough voltage to show up?Leave a comment:
if I was only interested in better hit registration and not the number of hits taken could this be used with just the original three wire plug and not have to add the extra two wires?Leave a comment:
Great job Joaquin! That Karl friend of yours is feeling inadequate.So my friend Karl got me into these fancy receivers, and something I did not like as soon as I received my order is the lack of a mount... so I decided to create a design on my own, and 3d print it for me and my friends.
The idea is to just glue in the bottom a 15mm magnet. There is a place in the base for that.
The top fits the IR receiver I got, hopefully all of them have the same size.
There is a hole in the side to route the wires.
Excellent! Great job..So my friend Karl got me into these fancy receivers, and something I did not like as soon as I received my order is the lack of a mount... so I decided to create a design on my own, and 3d print it for me and my friends.
There is a hole in the side to route the wires.Leave a comment:
I can work on some drawings. I’ll need Rubicons input since I think he has at least one of every HL tank for a base unit that will fit all the tanks yet cab be easily modified or cut down for each specific model..Leave a comment:
If someone wants to PM, sketches, dimensions, and or ideas I could design one. Im not set up for printing and selling though, but Ill just put the design up on thingiverse so anyone with a printer has access to it.
I agree. It is important to me to be able to easily move the IR device from tank to tank. Most people would like a plug and play system. I have had to help my friends who also bought Lego’s IR units install them. A useful mount would help a lot.Leave a comment:
karltrek, I had debated on doing a similar adaptation for the Lego receiver by using the stock magnet mount but after contemplated it for awhile it seemed just as easy to do the mount I posted on my Sherman. I did another recent mount similar to the one I did for the Sherman on my T-72. Since my tanks are for IR battling not display or BB only shooting models it didn't seem necessary to have a mounting system that didn't require a little modification on the turret.
With this said I do think a nice magnet mounting setup would be more accepted by more people. We need to find someone that has a 3D printer to make a "magnet" mount for the HL models that easily fits the LegoDEI receiver. Maybe we can get Bcuriosr to whip one out?!
It would have to have a provision to cut length before inserting the magnet so it could be "fit" to the various different HL tanks for optimum height.Leave a comment:
Looks good. It sits really high and that will make it harder to hit at close ranges, but then the Tamiya IR receivers on Sherman’s sit just as high and are hard to hit at closer ranges too.LegoDEI Heng Long IR Reciever V1.0. I just finished making a better mount and wired in the LED into my HL Sherman. I have the Red and the Blue IR unit. The LEDs on the Blue one do not work for some reason.
https://youtu.be/1jFxZ47wLAY
