Panzer III
  • Vaseline
    • 290
    I got a set off Ebay I will have to look who the vendor was, They have a lot of Mato and Torro parts. I haven't put them on my III yet so can't help you as to how to put it on.
    • Vaseline
      • 290
      za-empire is the vendor I got them from off Ebay and they are a Torro product
      • SoCalBobS
        • 2718
        • Southern California
        Yep,that’s the one!
        • Vaseline
          • 290
          Bob did you cut the opening on the inlets before you put the grill on?
          • SoCalBobS
            • 2718
            Naw, too lazy.
            • DavidN
              • May 2021
              • 3189
              • Los Angeles, CA
              The reason I asked because it came with 8 little nuts and a pair of frames with 4 holes on each. I just want to see the right way before I superglue them as there might be no turning back :-)
              • Vaseline
                • 290
                From the pictures I've seen the bolts go on the engine deck and the screen goes on first then the frame with the bolts
                • DavidN
                  • May 2021
                  • 3189
                  • Los Angeles, CA
                  The end of the bolt that goes through the hole of the frame is just too thick compared to the layer of the frame. If that how it should be, then I might need to grind that end thinner.
                  • quitcherbitchen
                    • 923
                    • Altadena, CA
                    Getting my PZ III ready for LA tanks. I put the adjustable track adjuster on the side that kept dropping the track off. Just need to trial it.
                    • DavidN
                      • May 2021
                      • 3189
                      • Los Angeles, CA
                      I received the long narrow barrel today. I replaced it right away. Much nicer to my eyes (5cm) instead of that bigger (75mm) barrel. I guess HL want the panzer III to shoot the 6mm bb, so the barrel gotta have the large diameter. I put the little MG red LED inside. It fits right. Next, send to the paint shop to get the desert color for the barrel. Then I can join Quitcherbitchen with his panzer III at the LA tank battle too.
                      • quitcherbitchen
                        • 923
                        • Altadena, CA
                        Where can I get Road Wheels? Zhang Tanks seems to be completely out of a lot of stuff including the Panzer III wheels. Everything I see available is $12 + shipping from Europe just for one wheel. Metal are super expensive and I don't think I need to make the tank any heavier with the small battery it has.
                        • DavidN
                          • May 2021
                          • 3189
                          • Los Angeles, CA
                          If you can't find them anywhere, and if you really need a set of plastic wheel, my input is to order a static panzer III and you can have all the parts you need from it. It is about $66 on Toucan website. I just saw someone on Ebay selling 2 plastic road wheels for $24 :-(
                          https://www.toucanhobby.com/1-16-sca...849-model.html
                          • DavidN
                            • May 2021
                            • 3189
                            • Los Angeles, CA
                            I took this tank to the LA battle in October 2021.
                            And on January 8, 2022, I will take it to battle again. It is now equipped with launched flashing light, driver aiming light, extra track links for more "protection", stowage rack and a correct 5cm long barrel.
                            • DavidN
                              • May 2021
                              • 3189
                              • Los Angeles, CA
ID:	333433Click image for larger version
                              • DavidN
                                • May 2021
                                • 3189
                                • Los Angeles, CA
ID:	333436Click image for larger version
                                • quitcherbitchen
                                  • 923
                                  • Altadena, CA
                                  Is there a rule about the height of the IR receiver?
                                  • Rubicon99
                                    • 3311
                                    No rule about height it just has to be on the turret and reasonable unobstructed.
                                    • DavidN
                                      • May 2021
                                      • 3189
                                      • Los Angeles, CA
                                      I forgot to press the IR emitter down when I prepared it for picturing. It should be lower as in the 1st picture from the battle in October.
                                      • DavidN
                                        • May 2021
                                        • 3189
                                        • Los Angeles, CA
                                        https://www.forgebeartanks.com/store..._Tank_Base.htm l
                                        • quitcherbitchen
                                          • 923
                                          • Altadena, CA
                                          Thanks David.
