Tongde Models
  • SoCalBobS
    • 2754
    • Southern California
    [By the way, this is not MY thread. Anybody with info is welcome.]
    First, I have to say to prospective buyers, WAIT! Wait until we know more. I've had a lot of problems, the last being a broken sprocket! I'm working with DKLMRC and he will be talking to the factory to resolve the issues. It'll be a nice tank if they get fixed. Witness the following:
    A couple more photos, now that the sun came out. It sure changes the perceived shade, doesn't it?
    Click image for larger version  Name:	IMG_3196.jpg Views:	0 Size:	292.5 KB ID:	367397
    Click image for larger version  Name:	IMG_3197.jpg Views:	0 Size:	228.1 KB ID:	367396
    • tank_me
      • Feb 2022
      • 1197
      Have you found a way to reposition the suspension arms to give the tank more lift? As in to make it look more like it's supposed to? It would probably require adding a track link or two. That would be my guess.
      • RichJohnson
        • 1276
        Will an Abrams or Pershing sprocket fit.
        • SoCalBobS
          • 2754
          No, doing something like that is in the future, when the gearboxes run the tank.
          • SoCalBobS
            • 2754
            Good thought. But both are too narrow. The Abrams is the closest, but it's 40mm and the M60 is 42mm.
            • Rubicon99
              • 3316
              Bob its not the width you need to look at it’s the sprocket hub “backspacing”. If either the Abrams or M26 have even a close to the M60 backspace then they should work. Given you will have to use Abrams or M26 tracks but will have a running tank (for Sunday 😉).
              • SoCalBobS
                • 2754
                Since the M60 gearboxes are dead, there's no point in swapping stuff. Maybe I can just push the M60 around? Actually I haven't set up the IR anyway. I will bring it for show and tell.
                • Rubicon99
                  • 3316
                  Wait...what? The gearboxes are dead!!! When did that happen? I have only been away for a few days I must have missed that post.
                  • tank_me
                    • Feb 2022
                    • 1197
                    Carson from DKLM RC just posted some metal upgrades that are coming soon for the TongDE tanks. Sorry about the order as I don't know why they randomly show as they do.
                    • SoCalBobS
                      • 2754
                      Has promise! From my experience though, two concerns: The gearbox cases are metal but what about the gears? And, the weak point would now be the idler. I see there is a metl tensioner to replace the plastic one, but how it screws into the plastic hull will take more stress. Fingers crossed.
                      tank_me, to your earlier post, to raise the height may be difficult with the torsion bar suspension. I'll leave that to others to figure out.
                      • Rubicon99
                        • 3316
                        That’s good to see the metal upgrades. But it will most likely be a while before they are actually available.
                        • SoCalBobS
                          • 2754
                          A while ago I found online the wholesale company that is manufacturing them. They wanted to know how many I wanted, minimum order 10! I'll wait for DKLM after CNY though.
                          • SoCalBobS
                            • 2754
                            So close! As you guys can see from my posts, I'm not letting go so easily on this challenge. Heng Long gears almost fit. The HL gears with the short shafts, like from my Panzer IV chassis, are the right diameter for the sprocket, the driveshafts are the right length, the axle screws are the same thread, everything would fit EXCEPT the mounting holes and some protrusions in the hull that brace the stock boxes. Both of these could be remedied but I won't do this unless as a last resort. After all, I've only had it for six days. (...ohh, so close...)
                            I will probably buy the metal kits - in for a penny in for a c-note - when they hit the market.
                            • SoCalBobS
                              • 2754
                              A FB post by DKLMRC states the metal upgrades raise the tank to a more prototypical height. No idea how, and he'll probably be offline until after CNY.
                              • ArmorBolt
                                • Dec 2020
                                • 72
                                You did a great job Bob! Looking forward to see it live in person during next tank battle in SD. BTW, what is your technique of making those tarp, bag on the tank. Thanks.
                                • RichJohnson
                                  • 1276
                                  Value gear makes great tarp rolls and cammo net rolls and crates.
                                  • SoCalBobS
                                    • 2754
                                    It's Value Gear. Resin cast, very detailed. Friendly seller.
                                    • SoCalBobS
                                      • 2754
                                      At the SD battle:
ID:	367945Click image for larger version
ID:	367946Click image for larger version
ID:	367948Click image for larger version
ID:	367949Click image for larger version
                                      • Vaseline
                                        • 290
                                        Bob
                                        That thing looks great on the battle field
                                        • Rubicon99
                                          • 3316
                                          A few close up photos of Bobs M60 taken at the San Diego tank battle day on Jan 22 2023. Bobs paint work makes a inexpensive tank look like an expensive tank. Good job Bob 👍👍
                                          Click image for larger version  Name:	E9C8DC02-4852-48BB-9C81-995156F2C3A1.jpg Views:	0 Size:	153.7 KB ID:	367973Click image for larger version  Name:	8F16A998-FF22-432F-98F2-6BF713388093.jpg Views:	0 Size:	183.7 KB ID:	367974Click image for larger version  Name:	65659481-4A15-4B16-A74B-72E0B9E5A814.jpg Views:	0 Size:	168.3 KB ID:	367975Click image for larger version  Name:	AE41EFDB-02FC-48DE-94D3-F73220CAB3B8.jpg Views:	0 Size:	150.1 KB ID:	367972
