CS-TK26 main Board
Do the sticks feel more “hobby grade” in there movement? Does the TX feel heavier and more solid?Originally posted by SoCalBobS View Post
I'm guessing the case is used for r/c drones, maybe that's why there's a screen, inactive here. The sticks are shorter than HL, so it's really for thumb control, not thumb and finger pinch. The gimbals seem pretty tight, throws are pretty short. It's not heavier, if anything lighter since it's mostly plastic. I'll know more when I start playing with it.Originally posted by Rubicon99 View Post
If it works out, the receivers are nearly half the price of an HL 7.1, and it has servo recoil and elevation. The instruction sheet says it's good for 4 to 12.6 volts. Guess that's why the big heat sinks.
Double facepalm…. Head shaking…RC tank parts and accessories I make
Can you test to see if it will bind with a 6 or 7 series TX?Originally posted by SoCalBobS View Post
Not yet. The instructions don't mention binding. The start/stop control is just different enough (separate start and stop buttons) that I don't feel confident that if I did bind the receiver to a HL Tx that I could get it back bound to the CS Tx. I tried to bind HL 6.0 and 7.0 receivers to it but wasn't successful. Doesn't mean it won't just that I don't know how. Yet.
Update: Info on DKLMRC says not.The more screws it takes to reassemble a tank, the more likely it is you left something out!
As Bob mentioned, Im sure multiple receivers would/should bind with a single Trans. I cant find the bind instructions anywhere but will admit I havnt gone in search of either. As far as binding with a 6-7.1 transmitter, I'm not goimg to try until the binding process has been verifed with this unit..Originally posted by Vaseline View PostI should have one in a few days. Was wondering if we can use multiple MFU's with one TX, Bob wasn't sure about the binding of this unit yet?
I'm looking forward to playing with it and will add my input to this set up. So far it looks pretty good Sound is amazing
The way the HL binds is by holding the tank start button on the transmitter and then power up the receiver. I wonder if this is similar to that? Is there a button to start up the tank on the TK26 transmitter or does it just run through the starting sounds once the RX is powered on after the TX?
CS has two buttons, one for start & one to stop, instead of one on the HL.Originally posted by tank_me View PostThe way the HL binds is by holding the tank start button on the transmitter and then power up the receiver. I wonder if this is similar to that? Is there a button to start up the tank on the TK26 transmitter or does it just run through the starting sounds once the RX is powered on after the TX?The more screws it takes to reassemble a tank, the more likely it is you left something out!
Thank God it has servo reversing.
Tank: The transmitter on this setup is layed out a tad different then the Henglong. The Machine gun fire for example has its own dedicated buttons. With that said, its a stong possibilty that the advanced settings could not be accessed because the fuction key is no longer the "2 button" cannon fire operation. The cannon fire is a 1 button press now and like Bob, Im hesistant about trying to bind the receiver to the Henglong 7.0 Trans, as I'm fearful of bricking the damn thing. I'll let someone else experiment with that.
