1/16 Tongde M24 Chaffee Modifications
  • #81
    OK, lets see what's going to be done on the gunners side of the turret. Once again, some great screen shots show how most M24 were setup.
    It's said a picture's worth a thousand words, and this image is talking to me, is it talking to you??? Model kit parts are usually made thicker so they don't get broken easily. The chunky piece that holds a 50cal gun barrel was made from a rolled piece of steel flatbar and welded on, and there's two of these pieces. Next we see a box of 50cal ammo strapped onto the compartment behind the turret. The Tongde small angle piece is correct, and I'll be using it for the purpose in the image. The part to the right of the ammo can is different from the Tongde supplied part. The original is a piece of steel shaft drilled out to hold the 50cal mount, and maybe even with the Ma Deuce attached to it, but I haven't seen any photos of one stowed like that. The drilled out shaft has two pieces of flatbar welded to it, and it's welded to the turret. The bent strangely shaped piece of steel plate is to protect the spare gun barrel, and possibly the stowed 50cal BMG. Lastly, the bracket above the ammo hatch from Tongde is a very nice representation with the exception it's thicker than the original. Yes, I'll be using that bracket.
    • #82
      Here's a couple more images of the same area of the turret that give us a better view of everything.
      This next image is of the same tank in very rough condition before it was restored. In the shadow of the welded on guard, another U shaped flatbar can be seen. Also, the lifting eye is clearly visible because the compartment has been removed from the turret.
      • #83
        Here's an image of the same area from above after the tank was restored. This image is looking forward standing at the rear of the turret.
        Here's an image looking to the rear of the turret.
        • #84
          OK, so a couple images of the sanded turret, and the Mantlet lifting bosses sanded off. And a couple of videos.
          Chunky gun barrel holder, and video.
          Short Video.
          • #85
            Strange antenna looking mount, and video.
            Click image for larger version  Name:	20260627_193815.jpg Views:	0 Size:	77.8 KB ID:	450157
            Short Video about the part.
            In this short video, I should've mentioned that this part looks the same as the center of the tripod 50cal BMG mount. Notice they even have same retaining hand screw on both of them.
Name:	Screenshot 2026-06-28 093310.png
            • #86
              Here's the sanded off Mantlet lifting bosses with video.
              Short Video.
              • #87
                Here's how I'll make the Turret and upper hull lifting eyes.
                Click image for larger version  Name:	20260627_201508.jpg Views:	13 Size:	117.0 KB ID:	450161
                Yes, paperclips are a perfect way to make the lifting eyes!!!
                LOLLLLL!!!!!!!!!!! Yes, I need 8 lifting eyes. I said 4 for the turret, and I mistakenly said 2 for the upper hull, but the upper hull needs 4 as well!
                Well, that's it for tonight, more progress to come!!! Have a great day tomorrow everyone!!! Cheers from RI.
                • #88
                  Thank you, Tank Me, and Tdriver113 for liking my paperclip idea. I appreciate you guys checking out what I'm doing.
                  • #89
                    Well, I'm going to apply a very light coat of Bondo on all the plugged holes. I have to go out later today, so I think that's all I'll get done today.
                    • #90
                      OK, so a bit of Bondo and scribed panel lines for today. More to come!!!
                      Short Video Bondo Sunday!!!
                      • #91
                        Have a great Sunday everyone!!!
                        • #92
                          I don't have a Chaffee yet, but it's nice to see what they can become. With the release of the Gecko Models Chaffee in 1/16, I've been considering doing a mashup with that kit or printing a Chaffee lower and using the upper from that kit.
                          • #93
                            Found this picture on the AFV site of how the M2 machine gun was supposed to be stored.
                            • #94
                              First off, thanks again, Tank Me for checking out my build.
                              I've noticed the release of the 1/16 scale M24 Chaffee model kit. From what I've seen, it looks like a good kit. But for me having limited funds for my hobby, the Tongde RC M24 was best for me. And of course, I enjoy scratch building. So, I'm making it into how I want it.
                              BTW, check out the image Tdriver113 found and posted in my thread; it will bring a big smile to your face!!!
                              • #95
                                Farst off, thank you Tdriver113, very much for checking out my build!!!
                                OMG!!! Thank you very, very much for finding the imafe of the stowed Ma Deuce on an M 24 Chaffee!!!!! I highly doubt I'd have found it myself.
                                • #96
                                  While not my cup of tea. I am following with interest and learning from your techniques. There is something very satisfying about scratch building . I also appreciate the skill of people who print. I have cursed my lack of ability to 3d print when I have made ten parts to get three usable ons.
                                  • #97
                                    Thank you very much for your interest, and following my build!!! I greatly appreciate it Meter Rat!!!
                                    I'm a retired machinist, and yes I love scratch building as many things I need.
                                    Yes, I also don't have the ability to create my own 3DP files. I have a nice 3DP, but I've hardly used it yet.
                                    Cheers from the USA!!!
