Well, finally got it from Germany, took two months and two days to get it to my door, no damage at all, nice packaging by Roban or whoever does that for them. I just built the same kit basically as the Magnum PI version, this kit also has the upgraded gears and linkage bellcrank levers. Started building it, now that we got some cooler weather, had to do some grinding on the wood where the front mounting screws slide in, they were to tight of a fit between the wood and the L bracket, dremel sander took care of the fit, just perfect, the mechanics slide right in with nothing rubbing on anything, fitted the canopy and boom, then worked on the cockpit be to make it removable, so I will be working on it more this week after work, here is the progress so far.
Pics will be up later.
