The PiNk Powercroco Scorpion " The Ultimate Mess"
Let me show you boys up close the pink nonsense were talking about that doesn't make you perform any better. The first thing that stands out is junction between the bell and shafted end bell. Its taken a hit or something there that he truly wants to cover up with this ugly pink paint. You can see the paint didn't grab the edges of the ribbing. Its going to look like **** in a short while. Mechanically the bell looks too short for the stator. It looks to be a franken motor of some type where he has used alot of washers so the winding heads fit. The solder job on the leads is as pityful as it can get and that FRESH copper already looks like s h i t. It must be 11 years old out the bottom of the drawer. the same place his rebuilds are coming from. Jurassic park!. If you put a scorpion HK from Dr Okon they way its made here in a Brenner Contra Drive it will literally be pulled apart axially and the 2 steel bearing would fail in a few flights. This is not a false claim it is a fact! The way you would change the color and have it look really good is through electrostatic powder coating that would ensure the edges got covered and it would look 10 times better and be more uniform. It would also last! I doubt the bell on this is balanced any more and you can see clearly it is a junkyard dog compared to the work we do here. Since he painted the entire stator the air gap clearance may also be compromised
This project CERTAINLY has a lower power density than the unpainted COTS machine. All the paint is an additional thermal insulator and additional weight. A silly gimmick to cover all the machines prior physical damage from a previous fail.
Ralph is from the GDR, and still searching for Atlantis but this isn't it.
Weder Sie noch Sebastian können einen einfachen Hybriden wickeln. Kleine Jungs in Blau.
"GWAZ" ? Es gibt keinen größeren Esel als Ralph. Es ist mir egal, ob Kunzke dem Ahnenerbe beitritt. Er wird früh genug feststellen, dass er keine afroasiatischen Wurzeln hat. Er ist kein Berber.
