What did you fly today?
  • Hoomi
    Cactus Dodger
    • Apr 2018
    • 863
    • Baja Arizona
    Originally posted by Skyboom
    It'll fly again. Once you straighten the fuselage out, cut some thin strips of balsa wood and glue inside the cowling. Hopefully the prop shaft isn't bent up.
    The prop shaft snapped right off.
      I flew a couple of planes along with my son.
      • CaptAmerica
        Ghostrider
        • Jun 2018
        • 187
        • Ohio
        Bit to cold to fly the Eflite Cherokee today so took this one around the patch for a bit.
        • F22trainer
          Piper PhD
          • Mar 2018
          • 1484
          • Sun City, Az
          The PT-17 and T-6 flew nicely, but I learned I needed to reset TX battery in System Settings when I switched to the Li-Ion rechargeable...did not get a “Transmitter Low Battery” warning.
          Crap
            :Straight-Face::Straight-Face::Straight-Face::(:(:Scared:
              Merry Christmas all..... F-22, ouch.... Enjoy the Season and Jesus is the reason!!!
                Crap
                Awe crap brother, sorry to see that. Fixable though it looks like. Hardway, Merry Christmas brother!
                • F22trainer
                  Piper PhD
                  • Mar 2018
                  • 1484
                  • Sun City, Az
                  Definitely fixable, and best Holiday wishes to you two fellow Texicans as well!
                    Pics of the 3d printed planes in the air
                    • Hoomi
                      Cactus Dodger
                      • Apr 2018
                      • 863
                      • Baja Arizona
                      Crap
                      Guess we both got bit by transmitter settings this weekend.
                      • Hemidoo
                        • Jun 2018
                        • 265
                        • Northern Vermont
                        Sent up the yard flyer to look for Santa this morning. Nice crisp 12°f on the deck !
                        Hope all the Squawkers here had a great Christmas day !
                          • 7325
                          Originally posted by Hoomi
                          From yesterday - hard lesson on not forgetting to check the rates switch before flying. Took off with the switch set at high rates, and the slightest movement of the sticks translated to LOTS of response from the plane. It seemed like everything I tried to do to get the plane back on level flight went too far, and it ended up nosing in. Not sure if that fuselage is going to be repairable.
                          Check out my rebuild of the E Flite Spitfire or the Freewing Mustang.
ID:	168592Click image for larger version
ID:	168593Click image for larger version
ID:	168594Click image for larger version
                          She was cracked right where the red line shows and with some skewers and a balsa plate behind the damage, and a bit of putty and sanding, she's ready for the air again. I found that if I use a towle with hot water and hit it with a hair dryer, it helped to saften the foam to a point where you could sort of reform it, then the rest is putty and sanding, it works, consider it a learning experience, you get better and better at it.
                          • F22trainer
                            Piper PhD
                            • Mar 2018
                            • 1484
                            • Sun City, Az
                            Tried a container of boiling water and dunked a fuselage and broken parts then just let it soak about 20 minutes and the foam would return to nearly normal shape with a little coating by flexing as it cooled to remove remaining warps. This Adagio was what I thought a goner, but Gorilla Glue and boiling water got it airworthy agin I did add a Balsa spar box and a few other refinements to correct some design flaws. She’s a great flyer now, even got one gifted to me that got crunched same as mine and it is nearly ready for RTS - previous owner will get first dibs as it was gifted after the crash. He just doesn’t know it yet.
                            • Woodcock
                              Old Returning Pilot
                              • Apr 2018
                              • 830
                              • SoCal
                              Happy New Year to ya Trainer!
                              Woody
                                Good times! Happy New Year brother!
                                • Woodcock
                                  Old Returning Pilot
                                  • Apr 2018
                                  • 830
                                  • SoCal
                                  Happy New Year Rman!
                                  Woody
                                  • Hoomi
                                    Cactus Dodger
                                    • Apr 2018
                                    • 863
                                    • Baja Arizona
                                    Yeah, I figure I've nothing to lose but some time in trying to repair it.
                                    Right now, my current project is taking a pair of wings I won at the RC Club Holiday lunch a couple of weeks ago, and building a glider with them. Taking my cues from the Flite Test guys, and building the fuselage out of foamboard. I bought a carbon-fiber arrow from Walmart for the tail boom, and balsa for the tail surfaces.
                                      Got in two good flights today at TIA on my F-22 and the canopy had no trouble staying shut in the air. I love this plane!!!
                                          Look at you sporting that white goatee, another 6 inches in it's length and your height and you could clone for George. LOL Miss ya Steve ;)
                                          Now to the serious comment.............SHORT SLEEVE SHIRT :P I had a couple layers of thermals on while handling steel in 34 degree temps :blueangry
