https://youtu.be/-EDAfE7dQVI?is=X8IlKY_QPvybQjk0 updated with sound system and the full rat tail logo
What did you fly today?
Finished Re-Powering my 1700mm FMS P-51 Red Tail. Installed an EFlight Power 60 (same motor in my 60" Beast Bi-Plane). Fit nicely and an 80 amp ESC is supposed to be adequate for it (same as the stock ESC), but I had a spare FW 130 Amp 6S ESC lying around from when I converted my 2 F-18's to 8S, so put that in it just to be safe. The most difficult part was props and spinners. The Stock 4 blade setup was 17" but reports existed that that setup would come apart using anything other than the 360Kv hampster wheel that comes stock. It also weighs a whopping 312 gr, no wonder it flew like a dog!
I was able to find 4" 2 blade spinners from Extreme Flight (aluminum back plate and plastic cone) and a 4" 3 blade all aluminum spinner from ZYHobby in China (surprisingly quick shipping). Finding decent props was also difficult. Tried a Master Air Screw 16X7 (Power 60 recommends a 2 blade 15X7 to 17X7) but that prop was also too heavy at 110 gr with a 20mm thick hub (supposed to be for both electric and gas but looks more like for just gas to me). So I contacted my Xoar "go to" Sales manager in China and she made me 2 17X17 two blade beechwood electric props in black with yellow tips and 2 16X7 three blade electric props black with yellow tips. Would have loved to set it up with a 4 blade, but couldn't find the right spinner (although Xoar would have made a 4 blade for me). Of course when it's in the air, no one will notice whether it's a 4, 3 or 2 blade prop as it "screams past them"!
I've had Xoar make me many different props (that can't be found in the US) and they always come through, only 4 weeks from order to arrival in Miami! They ain't cheap but IMO are the best electric beechwood props available, each meticulously balanced! The Xoar 3 blade weighs 65 gr, with a metal reinforcement sandwiched around the hub.
On the bench with an SMC 6S HiV 5900 mah fully charged, the 17X7 Xoar 2 blade pulled 96.6 ah and 2453 watts (I'm sure it will be less when flying free), the 16X7 Xoar 3 blade pulled 95.5 ah and 2368 watts, but the 16X7 3 blade Master Air Screw could only muster 77.9 ah and 1721 watts. I could hardly hold the plane down at fully throttle with either Xoar prop, but with the MA Screw there was a noticeable difference. I guess to get full benefit for the Power 60, it needs to turn up to 470 Kv and the MA Screw was just too heavy for it.
I did have to add an additional 3 ounces of lead in the motor compartment to make up for the stock heavy 4 blade to balance around 125-130mm.
Now to get it in the air! I think it will transform this aircraft just like it did when the Britts stuck a Merlin Engine in it!
It started out as a beautiful morning to fly. I got two flights in on my Flightline Corsair, one carrying the special Brewster drop tank support structure and 500# bomb used in the Pacific back in WWII for a while. This is a beauty designed by Elbee and I printed it up with his permission and the use of his stl file. Really a work of art. I've flown it probably on 10 flights in the past couple of years. Does not cause any problems to the flying of the airplane,and is held on by rare earth magnets. As long as the gear comes doen, it will survive indefinitely!
Had a few more controllability issues with it and when I landed on the second flight, the culprit was the servo for the right outboard set of flaps (just one flap). It is pretty much burned out, original equipment when I bought it in about 2018-19. It is my oldest airplane in active flying service, and I've decided to have it "stand down" while I order a replacement servo and while I'm at it, I'll order new retract units for the mains. I think those might be original equipment so they've been through the ringer, I guess about 200 flights or so, since new. It deserves a break while I make the changeouts.
I also flew my FMS F-86, the first time in a few weeks since I broke off one of the flimsy main gear doors on a landing. Flew great, but then the wind came up, a bad crosswind with a lot of turbulence. I had to buckle down and bring it home safely. It worked out, not pretty, but it landed with no damage. Phew!
A few pics of the Corsair after its flights this monring. The engine section of the fake radial was reworked by Danger Dan and me, and he did the same for his Marine version of the same plane, but with the birdcage canopy.
Cheers
Davegee
That 500 pounder looks just awesome 😎 😎... Dave.. great job.. same 4 me. She needs couple. servo and gear.. every so often I hear a little complaining about(what still no zero to fight). I simply say sorry and go inside
Thanks, Rex. I ordered a replacement servo for the outside right flap that completely failed today after about 6-7 years, (I think that was an original part) but I had to go with RC Castle in China to get replacement retracts for the mains. They still operate ok but shudder when they retract, a worrisome sign of impending trouble. The gear struts are pretty loose in the retracts so I figured it was a good time to replace them, too, while I'm about it. So, it will be down for a few weeks while I wait for these parts.
This model is dedicated to a fearsome warrior and aviator, Marine Lieutenant Robert M. "Killer Bob" Hanson in WWII. He was the all-time record holder for kills in the Corsair aircraft (25). Was set to rotate home for a rest when he was lost attacking a troublesome Japanese flak tower in the Solomon Islands in the South Pacific.
In Manila, Philippines, there is a beautiful cemetery, the largest military cemetery for Americans outside the USA. They have these monolith stones or slabs probably 20 feet tall each, with the names of the 40,000 who never returned from battle. Their names are all etched in stones, and some have a gold star next to the name, denoting a Medal of Honor recipient, which Hanson was (posthumously). I, along with my first officer on a layover took a cab over to the cemetery and did a rubbing of chalk on paper over Hanson's name as a keepsake.
Thanks, Craig. Thanks go to Elbee who did all the hard work and expertise to design up the parts and allowed me to print them up on my printer. I'm not totally certain, but I think VMF-215 did have some missions that used this early style bomb/fuel tank rack on some missions in the Solomon Islands in WWII. At any rate, it fits on beautifully with the use of a couple rare earth magnets that are glued on the ends of the struts that fit into the bottom of the fuselage.
Even wtih the most recent issues with the retracts and the failed flap servo today, this Corsair is one of the best rc warbirds I have ever flown. I never did keep score of how many flights I have done on my airplanes until just a few years ago, but I'm guessing I must have in excess of 200 successful flights on it now. I had one time where I was on downwind leg for landing and when I extended the gear, a black object dropped out of the airplane looking like a bomb! Turns out, it was one of the main wheels! I did a low gear pass to confirm this, but was able to land it with minimum damage to the airplane or the wheel-less strut. And, on top of that, I scoured the sage and cactus field where it was flying and actually found the wheel. Reinstalled it at home and it's been on there ever since.Comment
After installing new retracts in my Corsair and hunting down a problem where the outboard flap set on the right wing would not come down when commanded to do so, I got a couple of test flights in and it went great. I see now why this plane is one of my favorite warbirds. Also took the F-86 up for a couple of flights before the wind picked up. Two of my favorites at this point. I believe I got this Corsair in 2019. Lots of circuits and bumps around the pattern!
Everybody have a wonderful 250th anniversary and Independence Day of the good 'ol USA!!!
Cheers
Davegee
Due to a lack of replacement parts availability for the Flightline P-51D 1600mm model, I have had to order needed parts from China directly, using RC Castle. This process is vexing, as one small order I made last June 21, and we have no idea where it is, no tracking from USPS that it even made it into our country yet. I ordered a couple of replacement parts for the main gear, needing just one in particular to get my airplane flyable again. But who knows when that will come?
So, I have literally dusted off my retired EFlite 1.5M P-51D Hun Hunter from Texas, that I hung up in the rafters last year when it attained 100 flights. I figure I'll use this as my stand-in until I get my parts for the Flightline plane. To my delight, Hun Hunter flew beautifully today on three flights. It still can be a handful keeping it in control during takeoffs and landings, but today it went surprisingly well, despite the layoff of almost a year since I last flew it.
I have a few minor tweaks to correct like a sloppy tailwheel with a set screw that probably needs to be replaced, but it will get some TLC this weekend and I'll put it into the rotation with the other airplanes that I have for the summer. I don't see having my Flightline P-51 ready to fly for at least a month, or more as I wait for these parts.
Also flew my FMS F-86 which is just a delight to fly. It and my Freewing Cougar are just wonderful favorites to put in the truck and fly on any day I get the opportunity.
Trivia for detail buffs: On some P-51s in WWII there was a black cross on the left side of the fuselage next to the data placard. I recently found out what this signified. Anyone already know the significance of this cross?? I'm sure some of you already know.
Cheers
Davegee
Dave out of my 3 warbirds. I agree this one tracks the least straight on takeoff. Lotsa r rudder req.. I'm wondering if full as3x will help and turn it down once up. When I fly mine next will try and report hence. Would be good to have the throttle based gains like Jon on two brothers.. but we can't figure it out yet. Alsa not sure if you are spectrum. Oh do tell. The ❌Comment
Hi Craig: today's flights after a year layoff from flying it was a pleasant surprise. Not perfect but reasonable tracking for takeoffs and rollouts on landings. I tweaked the tailwheel setup at home this evening and will take it up for more flights on Monday. I think it is good practice for me while I'm waiting for my replacement gear parts to come from China, which could take weeks. I think flying this plane again to practice for the much better Flightline 1.6M which has been promising so far. I'll take advantage of this opportunity to use this plane to increase my skills when I get to fly the Flightline Mustang again later this summer.Dave out of my 3 warbirds. I agree this one tracks the least straight on takeoff. Lotsa r rudder req.. I'm wondering if full as3x will help and turn it down once up. When I fly mine next will try and report hence. Would be good to have the throttle based gains like Jon on two brothers.. but we can't figure it out yet. Alsa not sure if you are spectrum. Oh do tell. The ❌
I have an old Spektrum DX18 that I've had for many years. Eventually I'll probably upgrade to a newer transmitter, but I"m not in a rush as this one works well still, and I feel comfortable with it.
Cheers
DaveComment
Got seven (7) flights in on my EFlite 1.5M P-51D "Trainer" this morning. Landings are not a problem, and once the plane is in the air, it is one of the best flying warbirds that I have flown. Takeoffs are getting a bit better, all safe, if not pretty, but the last takeoffs I had I seemed to find a sweet spot in technique to get a decent and reasonably accurate takeoff to the real thing. I think this plane is one of the hardest warbirds to take off that I have had, and that might be good to get ready to fly my new Flightline P-51D Hurry Home Honey, that is waiting on a landing gear replacement part from China. I think HHH is probably easier to fly than this EFlite plane, so I hope that is so. Only have 3 flights on HHH so probably not a good comparison, yet.
Also, took up my Cougar for one flight. The plane is so clean without ordnance on it, it is wise not to land with any tailwind, and even just a crosswind it Sails down the runway, but usually stops with reverse thrust before the end of the runway. I do have a scale 3D printed speedbrake that is pretty effiective, which helps.
Cheers
DavegeeComment
After my replacenent gear part came in the mail last week, I got my Flightline 1.6m P-51D ready to get some more flights in this morning. I got 5 flights, was fairly happy with them, the last landing was the best so far for me. Takeoffs are fairly routine, I apply full up elevator to get it rolling straight ahead then release the back pressure and then concentrate keeping it straight down the runway as I feed in the power. Seems to work pretty well for me, anyway. I like the takeoff and landing performance on this aircraft much more than the EFlite 1.5m P-51D that i used to own for years. I think I'll keep this one!
Here's a couple pics after I finished the fifth flight this morning, making a total of eight so far. If I ever get the optional motorized wing pylons from China someday, I'll start experimenting with the drop tanks. Note the "surgical" removal of the tail fin fairing that was missing on the early P-51Ds like this one. It doesn't seem to affect flight performance at all, and didn't when I had done the same thing to my three E-Flite 1.5m P-51Ds.
Cheers
Davegee
Wow! that hack last night when I pulled up HS and only found a red page with "You have been Hacked!" was weird and disturbing. At first I thought my own computer had been hacked but then found out it must have been elsewhere as everything else seemed to be ok. Glad it is up and running again!
Thanks, Rex and Dan. I flew HHH this morning after the crosswinds died down to tolerable levels for me. Flew my FMS F-86 for a couple of flights and also the P-51 for two flights. This time on the second flight I added the pylons and OEM 75 gallon drop tanks to see how that affected performance. I glued them with a few drops of white glue just to keep them from flying free of the airplane in flight, as I hope to eventually get the electronic pylons that I can drop these tanks, bombs, and a larger tank that Dan and I are working on. But can't do much with all that until I get those electronic pylons. Who knows when that might be??! But if they do come someday, it should be good testing and pretty cool visuals dropping them from the airplane.
I'll attach a couple pics I took after today's flights.Any effect these might have on the airplane is negligible. The design and shape of these tanks is first rate.
Many times OEM tanks are not very accurate in shape or size. But these are great. Can't wait to eventually drop these in flight!
