New project... Boredom is a curse... Lol
    Agreed. That definitely would be worth doing to save pain
      And now the fun begins!
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        I have a Grumman Widgeon (De plane!, de plane!) which I was thinking of using the FL P-38 power plants on. I think this would be a great choice for your wing. Doc
          Heck yeah I'm waiting on the parts on
            And so it begins!
              I've got 3 layers glued together, that makes for a 2.25" thick wing. Im planning to start sanding either later this evening or tomorrow depending on if there's any daylight left this evening.
              • doctormike
                • Oct 2013
                • 1260
                • Santa Fe NM
                Looking good! What's the wingspan? Are you going to lay a spar in? Doc
                  6 foot and since I'm doing a complete fiberglass sheeting on it, I don't plan to use a spar inside
                  • doctormike
                    • Oct 2013
                    • 1260
                    • Santa Fe NM
                    That'll work, for sure. Good size! Doc
                      Heck yeah, what do you think if I use the original 6° up thrust angle on the motor pods, would I still need to add any reflex angle to the rear of the wing? I was thinking no since the upward angle of the motors would have the same effect.
                        Started the sanding process. Looking pretty good sofar
                          Wing is ready
                          • boomer108
                            Chief Boom
                            • Apr 2014
                            • 868
                            • Chicago IL.
                            Nice job Rifleman.:Cool:
                              Just finished cutting the control surfaces out. Waiting on parts to build the cockpit area and linkages. So that's the progress on day 2. Day 3 will consist of building the motor mounts and cutting wire and cooling channels. Once I have those done I can run some glass to strengthen those. And also have a anchor point for the screw down covers for easy access to the servos and wires. I'll also have a hatch on the motor mounts to access the escs. Just some ideas I've been playing with.
                              • doctormike
                                • Oct 2013
                                • 1260
                                • Santa Fe NM
                                Boy!...You don't waist any time, do you? Really looking good. How did you make both wings the same airfoil when sanding, templates or just eyeballing it? Doc
                                • mr.frankenjet
                                  Eat, sleep, FLY FLY FLY !
                                  • 448
                                  • Virginia, USA
                                  really sweet looking. I have glassed serveral planes with light cloth and minwax polyacrillic, takes allot of time but will come out surf board smooth. Some guys are saying Varathane makes a superior water based urethane, might be worth a shot. Good luck with him, great project.
                                  rc flyin addict
                                  • mr.frankenjet
                                    • 448
                                    • Virginia, USA
                                    heres some of the glass work, really stoked about your project, great plane.
                                    rc flyin addict
                                      Eyeballed it, and ran my had over the surface feeling for any deviation. And ups will be here late tonight, so that will slow down progress today. Then the last parts are the landing gear cups from the flight line p38 once those are in I'll be in good shape to push forward again. Right now I'm going to work on the motor mounts. I have alot of flight line/ freewing components in this. And I'm going to try the Istone stabilizer and see how it works
                                        Heck yeah that makes me feel good about that technique
                                          Motor pods are generally shaped I'm probably going to notch the exhaust in them haven't decided yet.
