3d Printed Part Sets - Freewing F-4D Phantom II
  • Flash Jorden
    • 77
    Very cool! Would love to see someone do a time lapse of some of these parts being created... :Cool:
    I wish I had remembered to start one, but I didn't I'm still printing the parts, so I can capture some.
    • Flash Jorden
      • 77
      Originally posted by bbaumer
      I had a slight problem at the end printing the "cap" but nothing to split hairs over, very pleased overall
      Looks like you printed without supports, and it turned out well. I added lots of supports (missed adding some). We'll see how it goes.
      • Flash Jorden
        • 77
        Quick question.
        What is MRC's stance/thoughts on guys printing these parts for a fee for others without printers? Not trying to start a flame war, just wondering.
        • bbaumer
          • Jun 2017
          • 152
          • Indiana
          I printed in what my software calls spiral mode, which kept the print times down ( about a third of what a normal print was going to run.)
          • bbaumer
            • Jun 2017
            • 152
            • Indiana
            Originally posted by Gringotuerto
            What printer are you using that has 20um resolution? My printer claims 20um minimum layer height, but if I choose the "high detail" preset it defaults to 50um. If I manually change only the layer height to 20um, it prints much worse....looks like it is melting what it already printed, and just making a mess. Maybe I have to change many other things to avoid this. I tried messing with some of the other parameters (fan, etc. ) but I never found anything that prints better than the "high detail" default settings with 50um layer height.
            I have a Cel Robox
            Quick question.
            They specifically ask you not to monetize the files in any way
              Partially 3D printed of my own design. Making a 'J' model Jolly Roger so I need the longer style nozzles.
              • bbaumer
                • Jun 2017
                • 152
                • Indiana
                Pretty neat, and a huge upgrade from stock
                • bbaumer
                  • Jun 2017
                  • 152
                  • Indiana
                  Do you have 3d modeling experience? you did a nice job with those.
                  • buffetbob
                    Incurable Warbirdholic
                    • 22
                    • Tampa, Fl
                    I'm all for it! Especially for the A-4 and A-10 models. Bob
                    • Flash Jorden
                      • 77
                      Thanks. Reading is fundamental. Somehow I missed that line when I read the post the first time. I'll blame it on my excitement.
                      • TMoyer
                        • 32
                        I will definitely be purchasing these when I get my F4. It would be great to also see some of this stuff for my F14 as well!
                          This was my first time modeling a piece to print. Don't be too impressed... the detail on the outside of the nozzle is sheet styrene that I added. I just designed the basic shape but it did fit like I wanted it to.
                          • Flash Jorden
                            • 77
                            Here is the final result of my 1st 3dPUP print minus the ladders. Total weight is 240 grams. I'm still trying to get the print/printer dialed in. This was with silver/aluminum colored filament.
                            Total print time was 21 hours, 25 minutes. Mostly because I used a lot of supports.
                            Click image for larger version  Name:	20180324_000834.jpg Views:	4 Size:	151.7 KB ID:	124842Click image for larger version  Name:	20180324_000947.jpg Views:	3 Size:	69.6 KB ID:	124843 Click image for larger version
ID:	124845Click image for larger version
                            • Flash Jorden
                              • 77
                              Here a quick video of some of the print job
                              • Flash Jorden
                                • 77
                                2nd print attempt with white filament, changing the object positions (flipped the nozzles, adjusted the panels). Greatly reduced the amount of supports just to see what happens. Hoping for "cleaner" parts. Reduced the print time by several hours.
ID:	124849Click image for larger version
Name:	Freewing F4 Parts v2.jpg
                                • bbaumer
                                  • Jun 2017
                                  • 152
                                  • Indiana
                                  Here's my best shot at some cockpit panels. I'm coming to the conclusion it's going to be very difficult to recreate the quality you see in Motions pre-printed parts on any level of hobbyist 3D printer. I think I'll be able to get "good enough" level, but at the price of $20 or so the factory prints will be a bargain and will likely be the highest quality prints available. For those of you thinking of buying a printer, keep this in mind.
                                  Click image for larger version  Name:	 Views:	1 Size:	46.3 KB ID:	124869
                                  • Flash Jorden
                                    • 77
                                    Based upon my current printing attempts, I agree 100%
                                    bbaumer, what speed and other basic settings are you using, if you don't mind sharing?
                                    I'm using Simplify 3D printing at .2mm layer height, 2 perimeters, 100% infill (not that it needs that much, 30-50% would probably work well), 210/60C temps, at 50mm/s.
                                    • bbaumer
                                      • Jun 2017
                                      • 152
                                      • Indiana
                                      Well, interestingly enough, my printer is a "plug and play" one. The software is called AutoMaker, and it is proprietary to the printer.
                                      I've got 3 basic levels of detail to select from with standard printing, or I can select a spiral mode. I've never dug into the custom settings much. Looking into it, the fine settings are
                                      .10mm layer height 40% fill, 3 perimeters, speeds are .8mm/s on first layer, 25mm/s pretty typical elsewhere, i'm using a .3mm nozzle and printing with PLA
                                      It also calculates all its own supports, you can see those in my earlier picture as the lattice work underneath parts
                                      Temperatures are read from an EEProm on the spool, including bed and head temps
                                        So are you guys using PLA for the cockpit parts as well? Just curious.
                                        • bbaumer
                                          • Jun 2017
                                          • 152
                                          • Indiana
                                          I do use PLA on anything non structural. I find it easier to finish, particularly since it can be smoothed with acetone. Please excuse the focus andrough paint job on Col. Olds head here but notice how smooth I was able to get the helmet
