I reprinted the centerline tank with just one outer layer (Vase Mode) in Simplify 3D and now it is just 2.8 ozs. Yes it is not as rigid as my original print but it still seems plenty stiff enough for the application. I reinforced the flat mounting surface by gluing some 1/8" lite ply inside it and will probably install two of the mounting rails to hold it on. Adding some primer to it now. Getting a 3D printer has been one of the best investments I could have made. It has opened up a whole new world of detail potential. I need to work on my designing skills.
3d Printed Part Sets - Freewing F-4D Phantom II
I only love you for your printer :Silly:I reprinted the centerline tank with just one outer layer (Vase Mode) in Simplify 3D and now it is just 2.8 ozs. Yes it is not as rigid as my original print but it still seems plenty stiff enough for the application. I reinforced the flat mounting surface by gluing some 1/8" lite ply inside it and will probably install two of the mounting rails to hold it on. Adding some primer to it now. Getting a 3D printer has been one of the best investments I could have made. It has opened up a whole new world of detail potential. I need to work on my designing skills.
LOLWarbird Charlie
Those look AH’MAZING man! Can’t wait for my printer to get here and get started! Any chance of a centerline tank for the Freewing F-16 too? I think it’s about 1/10 scale.I have completed some ordnance / external storea and uploaded them to thingiverse.
https://www.thingiverse.com/thing:2867005
https://www.thingiverse.com/thing:2859866
https://www.thingiverse.com/thing:2851605
https://www.thingiverse.com/thing:2852099
A big thanks to rcjetdude for the help with the 600 gal centerline tank.
2 PhotosComment
I know a lot of people have been looking to add the centerline for the scale appearance. Willing to test fly it on mine and see if it interferes with the cheaters. Just ordered the 1680 HET motor for it. Eventually hoping to convert the 90 to the IAF SUFA with the 2 seat canopy, top conformal tanks and avionics spine.
Here is some reference links I found.
https://www.super-hobby.com/products...#gallery_start
http://www.greenairdesigns.com/ejcga..._display_media
http://www.hyperscale.com/2007/revie...reviewme_1.htm
http://scaleindetail.com/index.php?route=product/product&product_id=264
I had that happen to me too - it's the resolution. Choose the finest resolution first and then the slicer will see it and the fins will appear like magic when you generate the preview. Gotta love these 3D printers.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
I am having trouble finding a "resolution" setting in Simplify 3D... might be called something else. I wouldn't mind thicker fins myself. Technically they maybe should be thicker since they are really two fins coming together anyway?Comment
Check if Simplify3D has some feature similar to "detect thin wall sections". If your nozzle is 0.4mm sometimes the program might not print sections less than 0.8mm as the printer is expecting to draw a full perimeter instead of a single pass.Comment
Here's a hanger I designed to use with my sparrow prints since I didn't incorporate the MotionRC Hanger cleats, simple, but seems effective, the hole is designed to accept a common hex drive collared servo screw, but many could be used. This also lets you spread the anchor points out as far as you'd like, and use as many as necessary for larger prints
Attached Files1 PhotoComment
