I reprinted the centerline tank with just one outer layer (Vase Mode) in Simplify 3D and now it is just 2.8 ozs. Yes it is not as rigid as my original print but it still seems plenty stiff enough for the application. I reinforced the flat mounting surface by gluing some 1/8" lite ply inside it and will probably install two of the mounting rails to hold it on. Adding some primer to it now. Getting a 3D printer has been one of the best investments I could have made. It has opened up a whole new world of detail potential. I need to work on my designing skills.
3d Printed Part Sets - Freewing F-4D Phantom II
Originally posted by RCjetdude View PostI reprinted the centerline tank with just one outer layer (Vase Mode) in Simplify 3D and now it is just 2.8 ozs. Yes it is not as rigid as my original print but it still seems plenty stiff enough for the application. I reinforced the flat mounting surface by gluing some 1/8" lite ply inside it and will probably install two of the mounting rails to hold it on. Adding some primer to it now. Getting a 3D printer has been one of the best investments I could have made. It has opened up a whole new world of detail potential. I need to work on my designing skills.
Originally posted by apmech1 View PostI have completed some ordnance / external storea and uploaded them to thingiverse.
600 GALLON centerline fuel tank and pylon---- Updated to better scale and pylon mount Added Hollow version
A big thanks to rcjetdude for the help with the 600 gal centerline tank.
2 Photos
Originally posted by apmech1 View PostSure, let me dig up some dimensions and see wat I can come up with.
Here is some reference links I found.
https://www.super-hobby.com/products...#gallery_start
http://www.greenairdesigns.com/ejcga..._display_media
http://www.hyperscale.com/2007/revie...reviewme_1.htm
http://scaleindetail.com/index.php?route=product/product&product_id=264
Originally posted by RCjetdude View PostWhen you get a chance can you check out the fin section of the MK-82's you did? When I see it in my print preview the fins are missing so I am not sure about trying to print it.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Originally posted by RCjetdude View PostI am having trouble finding a "resolution" setting in Simplify 3D... might be called something else. I wouldn't mind thicker fins myself. Technically they maybe should be thicker since they are really two fins coming together anyway?
Here's a hanger I designed to use with my sparrow prints since I didn't incorporate the MotionRC Hanger cleats, simple, but seems effective, the hole is designed to accept a common hex drive collared servo screw, but many could be used. This also lets you spread the anchor points out as far as you'd like, and use as many as necessary for larger prints
Attached Files1 Photo
