3d Printed Part Sets - Freewing F-4D Phantom II
    I reprinted the centerline tank with just one outer layer (Vase Mode) in Simplify 3D and now it is just 2.8 ozs. Yes it is not as rigid as my original print but it still seems plenty stiff enough for the application. I reinforced the flat mounting surface by gluing some 1/8" lite ply inside it and will probably install two of the mounting rails to hold it on. Adding some primer to it now. Getting a 3D printer has been one of the best investments I could have made. It has opened up a whole new world of detail potential. I need to work on my designing skills.
      I only love you for your printer :Silly:
        LOL
        • JLambCWU
          • 267
          Originally posted by apmech1
          I have completed some ordnance / external storea and uploaded them to thingiverse.
          https://www.thingiverse.com/thing:2867005
          https://www.thingiverse.com/thing:2859866
          https://www.thingiverse.com/thing:2851605
          https://www.thingiverse.com/thing:2852099
          A big thanks to rcjetdude for the help with the 600 gal centerline tank.
          Those look AH’MAZING man! Can’t wait for my printer to get here and get started! Any chance of a centerline tank for the Freewing F-16 too? I think it’s about 1/10 scale.
          • apmech1
            Warbirds old and new
            • 266
            • CVG Airport, Kentucky
            Sure, let me dig up some dimensions and see wat I can come up with.
            • JLambCWU
              • 267
              I know a lot of people have been looking to add the centerline for the scale appearance. Willing to test fly it on mine and see if it interferes with the cheaters. Just ordered the 1680 HET motor for it. Eventually hoping to convert the 90 to the IAF SUFA with the 2 seat canopy, top conformal tanks and avionics spine.
              Here is some reference links I found.
              https://www.super-hobby.com/products...#gallery_start
              http://www.greenairdesigns.com/ejcga..._display_media
              http://www.hyperscale.com/2007/revie...reviewme_1.htm
              http://scaleindetail.com/index.php?route=product/product&product_id=264
              • apmech1
                • 266
                I think I've got the basic shape down, now I just need to know the full scale length of the tank.
                • bbaumer
                  • Jun 2017
                  • 152
                  • Indiana
                  It's past "late April" whats the status on the MotionRC printed sets ? I've got some other things locked up on an order with the cockpit set
                  • apmech1
                    • 266
                    Originally posted by JLambCWU
                    Took some math, this should be the length
                    That's like 49 feet?
                    • JLambCWU
                      • 267
                      Whoops! Wrong screen shot! Aircraft is 14.8 meters, and the tank is 4.5 meters
                      • apmech1
                        • 266
                        Cool, thx
                        • apmech1
                          • 266
                          I have the F-16 Centerline tank done.
                          https://www.thingiverse.com/thing:2898833
                            When you get a chance can you check out the fin section of the MK-82's you did? When I see it in my print preview the fins are missing so I am not sure about trying to print it.
                            • themudduck
                              -TMD- Foaming at the Mouth!
                              • 1041
                              • Burton OH (near Cleveland)
                              I had that happen to me too - it's the resolution. Choose the finest resolution first and then the slicer will see it and the fins will appear like magic when you generate the preview. Gotta love these 3D printers.
                                Can't seem to get it to work...hmmm.
                                • apmech1
                                  • 266
                                  I printed them spiral at .06mm resolution. If that doesn't work let me know and I will redesign the aft section with thicker fins.
                                    I am having trouble finding a "resolution" setting in Simplify 3D... might be called something else. I wouldn't mind thicker fins myself. Technically they maybe should be thicker since they are really two fins coming together anyway?
                                    • apmech1
                                      • 266
                                      Mk82 with 1mm thick fins
                                      • Dirty Dee
                                        • 768
                                        • Northern Illinois
                                        Check if Simplify3D has some feature similar to "detect thin wall sections". If your nozzle is 0.4mm sometimes the program might not print sections less than 0.8mm as the printer is expecting to draw a full perimeter instead of a single pass.
                                        • bbaumer
                                          • Jun 2017
                                          • 152
                                          • Indiana
                                          Here's a hanger I designed to use with my sparrow prints since I didn't incorporate the MotionRC Hanger cleats, simple, but seems effective, the hole is designed to accept a common hex drive collared servo screw, but many could be used. This also lets you spread the anchor points out as far as you'd like, and use as many as necessary for larger prints
