3d Printed Part Sets - Freewing F-4D Phantom II
    Now you tell me! :)
    • Helmsman52
      • 247
      • Saint Paul, MN
      Now you tell me! :)
      I had a late brain fart lol
      • Dirty Dee
        • 768
        • Northern Illinois
        Not to be duplicating efforts, but I made a 600 gallon centerline tank as well. Bartered with dlxpkg for a pair of wing bags for my A-10 in return for a printed centerline tank:)
        Some design differences from apmech1's, like utilizing the stock FW hardware as well as I added the aft sway braces. Will upload to thingiverse after I finish printing them and make sure they are good.
          DD,
          I like your idea of adding just the slot for the slide on attachment. Less supports needed that way. Looking forward to seeing it on thingiverse!
            Looks good DD. Just a personal note: On a part that size I use two brackets to help distribute the load. My preference but just in transport alone it is subject to getting bumped. It is very solid with two and it also helps to keep it aligned.
              • Nov 2013
              • 2794
              • Cody, WY
              I bought the upgrade F-4 cockpit parts as well as the two engine exhaust upgrades. Everything worked out pretty well, however on the cockpit parts I had two parts left over and I have no idea where they go. I"ll post a pic of them. Can anyone tell me where these are supposed to go on the airplane?
                Those are chin modifications for the nose cone. The straight one turns it into a C model (stock is a D model). The one with the bump is for a plastic chin for the D model.
                  • Nov 2013
                  • 2794
                  • Cody, WY
                  Thanks, Pat!
                  • Alrus1
                    • Dec 2014
                    • 19
                    Downloaded stl files, ordered SLA printer. Would try to print those parts. Wish me luck!
                    Second to None
                    • Jhnybgd
                      • Dec 2017
                      • 262
                      Hey guys can anyone make a scale tailhook for the F4,I would really like to make it functional.
                      • fhhuber
                        • Aug 2015
                        • 1476
                        Functional as in using it to catch a "wire" on the runway to do an arrested landing?
                        that would require a far more secure attachment than is needed for the landing gear. It would impose several G of deceleration force on the aircraft.
                        I've done arrested landings with control line. 1 lb sandbags each end of the arresting wire, 1/2 inch thick solid balsa profile fuselage with 1/8 inch thick aircraft plywood .reinforcing plates at the tailhook attachment point, 8-32 bolt as the pivot pin, and commonly sheared the bolt. (which was the cheapest thing to have break if the landing was too fast)
                        And that was a much lighter and slower model.
                        • Jhnybgd
                          • Dec 2017
                          • 262
                          No don't plan on actually stopping plane.
                          On my t45 when I drop landing flaps I have the tailhook also drops,have servo connected to a spring when the tail hook contacts the ground it just floats .
                          Doesn't do anything except look amazing on final with everthing down and dirty.
                          I have played with trying to catch streamers on the runway.
                          • Dirty Dee
                            • 768
                            • Northern Illinois
                            Here is the centerline tank. 94g with ABS and printed in 3 parts. I should have it up on Thingiverse tonight.
                            • TMoyer
                              • 32
                              Is the 145XR in the background an RC model or a static model? Pretty cool.
                              • Dirty Dee
                                • 768
                                • Northern Illinois
                                It's static until I finish a few repairs:).
                                twin 50mm, can get a good 6 minutes of flight time on 2650mAh 4S.
                                  • 4878
                                  Hey Y'all, For those who have been waiting for the Motion RC 3DP F-4 cockpit kit, it is now back in stock. Just received a notification. Best, LB
                                  • Dirty Dee
                                    • 768
                                    • Northern Illinois
                                    Here is the thingiverse for the 600 gallon centerline tank. I have 2 versions of the tail piece uploaded depending if you want to ad a second attachment hardware or not.
                                    https://www.thingiverse.com/thing:3010216
                                    • vduniec
                                      Hobby Squawk Pilot
                                      • 314
                                      Love all the stuff you're posting on Thingiverse. Thanks for sharing! I'm relatively new to the 3d printing scene. Can I print this tank in PLA? What are the advantages of one over the other?
                                      • Wobisch
                                        • 83
                                        • Merenschwand, Switzerland
                                        I have printed the center tank and I am super excited. My new ABS with anti warping technology works fantastic. Thank you Chris.
                                          • 4878
                                          Wo-B, What is 'anti-warping' technology? A different formula or a technique you have discovered? I must know.Best, LB
