3d Printed Part Sets - Freewing F-4D Phantom II
Posting here to see if anyone is interested in designing/printing these High Drag SnakeEyes with Operating Fins. I would like to have the Fins lock up when attached to the Rail and spring loaded open upon release. Either MK-82/MK-83 can be done. Prefer the larger MK-83's. I can provide limited assistance with the project if necessary. PM if you'd like to discuss this. A servo actuated Pylon mounted Weapon Release mechanism will need to be designed/printed as well. Thx
That would be one fiddly mechanism to make those drag panels open, but still lock fully closed at speed in flight...
Very thin walls to print too.
I'd think you want to make the drag panels from soda can. With the slider from machined aluminum on aluminum or CF tube.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
I can see where one might think this. Let me explain Not attempting to copy this mechanism on here, it's far too complex for our needs on this. We simply need to copy the shape of the Drag Panels. Pin hinged at the rear, they open as the airflow moves across them when released. There is a Capture hook up in the inside of the Fin at the trailing edge that goes down into the Bomb body. That capture hook x4 is engaged by a spring loaded ring inside the bomb body which keeps them closed when Bomb Body is mated to the pylon. Upon release from the Pylon, as the release mechanism moves to free the Bomb and the bomb separates from the Pylon, that locking capture ring moves to release it's grip on the Fin capture hooks. The bomb drops away, the drag panels open and the bomb spirals down to be retrieved.
I've got this all figured out. Just need help from a crafty Feller who can 3DP up some Drag Panels (Fins), pin hinged at the rear and a Bomb body with some simple internals. Anyone interested can pm me to discuss. Thanks
Hey Y'all, back to the Phantom after our lil' trip. 3DP Nose Gear Door and 3DP Pilot/RIO Bodies with JHH helmets (I waited a couple of months for these guys, so I had to use 'em LOL) Cockpit almost there once I dirty it up a bit. Best, LB
7 Photos"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
AMA#116446Comment
LB, if you can't stop, I'm sure there are a few of us here that would GLADLY, send you a few more to work your magic on.:)Comment
Magic...yeah, that's the ticket...magic. But you mean Jedi Librarian/Garbageman/Homemaker/Plumber/Electrician/Lawn Boy magic, right?. That be me!!! I love you Guys, in that camaraderie sort of way. Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
Hey LB,.. Do you have a good FlyingSite picked out for that Jet of yours ?? Looks like you're getting close to 'The Day' !! CheersComment
BBR, I would think by Easter if the weather is decent here, however there is still a novel's worth of nomenclature to add, finish the painting of all ordinances, pylons, nozzles, walkways, anti-glare, landing gear, tailhook, some weathering, assemble airframe, touch up, apply a matte coat, install the radio, and test stuff, pictures...whew, I love this hobby. Best, LB
AMA#116446Comment
Hmmmmm,... IndependenceDay or HappyHalloween .... with those 20,000 outstanding rivets .. HahahahaComment
AMA#116446Comment
[QUOTE=Elbee;n185854]Hey Y'all, And 2&1/2 months later: Before (OEM) and After (3DP) F-4 A/C and Electronics Cooling Intakes. WooHoo. looks like I need to add a 2nd coat-o-paint, though. Best, LB
... QUOTE]
Awesomeness !! Now that is a very nice touch !!Comment
Nice work on the F-4, looks great! Love that Cobra in the background!Comment
AMA#116446Comment
