  • Rcfiddy1
    Some l39 fun...
  • BlueQ
    Alpha:"Hi Rudi, the one advantage of the L-39 shipments bound for Europe being delayed is that ALL of them included gunpods in the box before they left the factory. So yours will be in there! Thanks for your patience and support!"
    No, it isn't :Angry:
  • urrl
  • bill34207
    Happy Thanksgiving all. I spent the morning flying the L-39 and shot 5 videos total. This one is just some highlights from the 5 SoloShot clips shot today. Featuring the take off and landing from the medium mode experiment with some of the better moments from the wide mode videos
  • Quickstop
    Originally posted by Felixs10
    Added some color to the drop tanks . Looks a lot better in person . Should also aid in orientation. Is it just me or does the L-39 look a little like the star fighter in the air ?
    It's you:Silly:
  • urrl
    Morning flight
  • Felixs10
    We had a guy lose his on the rollout during the maiden. Experienced pilot, lost all nose gear steering. Duplicated problem with the carcass but not when box was sent in
    The BEC voltage issue makes complete sense
    I think you're onto something about the BEC voltage. I may try to power my board separately to see if I can get my issue to go away.
  • Quickstop
    Did you try following the steps on the Knowledge Blog on the MRC site? Might be worth trying to see if it fixes your issue.
    https://www.motionrc.com/blogs/motio...d-mcb-e-issues
    Yes, at least twice.....nothing:Scared:
  • Gilatrout
    My bluebox story; when I first plug in battery and lower the gear and taxi away the nose gear wont steer for the first two inputs of the rudder stick, then comes to life and works perfectly after that. OK I can live with that. Yesterday I go to show my friend the issue and suddenly nose steering won't come to life no matter what I do, replug in batt, restart xmitter, nothing! Put it in car and take home, get home and try again, comes to life like nothing happened.....Ugh:Angry::Thinking:
    We have encountered some customers who have been having issues with their L-39 MCB-E control box. T hecustomerswho call with problems areconnectingeverythingto the control box andputtingthe gear downa...
  • Quickstop
  • Ron1950
    I had a bad aileron servo so mrc sent me another. after installing it the other aileron went crazy chattering so I y harnessed the ailerons to the rx that makes rudder and nose gear steering y harnessed and the gear 3 y harnessed direct to the rx with only the flaps and lights in the blue box..btw they all ready sent me a new blue box but will not use it after all ivebeen through with the old box
  • seaviper
    We have three L-39's at our club. Two fly with everything run through the box. Mine has nose wheel steering on separate channel. All work fine. Never had a problem.
    Maybe they had a bad run of boards. If the board has a problem, just use a y-connector or another channel.
  • RMatteson
    Yesterday I switched a 6 ch. to 8ch. rx in my L-39 so I could separate nose wheel and rudder, to have a separate trim for both. I bound my rx with a NIMH that read 5 volts on volt meter and had no problems. I then disconnected battery and plugged in lipo to test fan, all was good. I always set up radio with throttle plug out and use a spare 4 or 5 cell battery to get every thing set, before I plug in lipo to set esc.
    RICK
  • Dp123
    Originally posted by Wayne@MotionRC
    Update on the L-39 Control Board testing. After getting back 15 Boards I have yet to have one that did not work for me. I thought I was onto something with DSM2 as it did not work with an older AR7000 but then I tried an AR6100E which is also DSM2 and it worked with that one. I wish I had what we could call a truly defective Board to send back to Freewing for testing but they all end up working. I have nothing to point a finger at yet but will keep looking. These boards also worked with our Admiral Receivers in case anyone was wondering.
    Gents,
    I also have been having problems with the board. In my case, the rudder works fine with the gear up, but stops working when the gear goes down.
    The excellent customer service guys at Motoin sent me a replacement box, which I tested on the bench, and it worked perfectly. But when I installed it into the model, the problem reappeared.
    so, out it came, and back on the bench to test. After trying everything I could think of, I finally managed to replicate the fault on the bench.
    I had been testing it using a 5 cell NiMh battery, and could not reproduce the fault. When I replaced the battery with a 4 cell NiMh, the problem instantly reappeared.
    i changed the battery several times, to make sure the fault was reproducible, and it happened every time.
    My conclusion is that it would seem that the box needs 6 volts to work, but the BEC is only giving 5 volts.
    Hopefully Wayne or somebody can also try this to confirm if it works for them too?
    I won’t make any changes to my model until I am sure that this really is the problem.
    Regards,
    Dave
    Welcome to the Squawk!! The L-39 is a nice flier for sure!!! :Cool:
  • adb2@suddenlink.net
    I've had my Albatros for about a week now and maidened it yesterday and I must say I was thoroughly delighted. I have three Avantis which I am really fond of but I must say that the Albatros in my opinion is equal to or perhaps even better than the Avantis. I believe it might be a little faster and the handeling seems a little better and approaches and landings to me are just easier. I certainly consider it a real winner. Watching the build and electronic videos made it very easy to put it together.
  • StormyDog1962
  • seaviper
    What happened was the spinner got a little loose and rotated slightly. This caused vibration which killed the front bearing.
    i put a little loctite in the screw hole, then rotated the spinner until i got smooth operation. I held the fan unit up against the plastic poles on the robart stand when testing for vibration. Its really very apparent when the fan is out of balance.
    anyway, she is back in service.
ID:	162345Click image for larger version
