  • Quickstop
    • 275
    Originally posted by Marksj100
    Everything appears to be in the correct place on the board in the wing. I may just bypass the board and have them on permanent, shouldn’t use much juice
    Mine worked,but I bypassed it and plugged them in to the double flash input. Looks great and can actually see them from quite a distance. Have a feeling that the battery would run them for days
    • adb2@suddenlink.net
      Advanced Pilot
      • Nov 2018
      • 104
      • Abilene Texas
      I have a question. Just put my L-39 together. The landing lights don’t come on when the gear drops. They do work as I have tested them with a battery at the main wing board
      thanks
      I found when installing the wing tanks it sure was easy, because of the tight fit, for them to become unplugged.
      • Marksj100
        • Aug 2018
        • 9
        I thought about that so I tested them at the wing board and they worked fine. Anyhow for some reason they work now when the gear is down ????. Still may plug them in to stay on
          Advanced Pilot
          • Nov 2018
          • 104
          • Abilene Texas
          They only work when the gear is down for landing. At least on mine that is the way they work.
            • 8817
            I believe these boards use one or two common grounds for everything. Yours may have had poor contact on some of the plug pins. I had that on an early version of these boards and by unplugging each one and wiggling them vigorously back on, stuff that didn't work started to work. Poor pin contact can be a random, on/off sort of thing.
            • JDill
              FrSky Thumber
              • 12
              • Traverse City, Michigan, USA
              Stuart shows how to do this in a MotionRC YouTube video, maybe you've seen it... link included.
              • Petronio
                • Dec 2017
                • 171
                Owe an update here after having been flying the Albatros for the past weeks. That the flight is absolutely delicious we already know from all the positive feedback from the guys, even that it is efficient but did not expect it to be to this extent. The past days we have been flying the Albatross perfectly at around 35 / 40% throttle stick, cruising around comfortably and even at a very reasonable speed squeezing up to 6min out of the stock setup..what and amazing flier and how aerodinamic the design is. Yet to see it stall too... Initially I had my timer set at 3min but ultimately after taxiing back my radio shows -3min with a voltage of 3.80V per cell. I could still squeeze it up to more than 6min I am sure. Kudos Motionrc & Freewing!
                • Deegeedoo
                  RC Pilot Airplane
                  • 7
                  • Elliot Lake, Ontario
                  It was already done. ;)
                  https://www.thingiverse.com/thing:3134218
                  I've already printed one and installed it. Works perfectly!
                  Thank you Pat,
                  I think that is a very smart idea. There is no one near who has a 3D printer so I'll make one out off aircraft plywood.
                  Rudy
                  • MANFRED
                    Any Warbird, any time
                    • 299
                    • San Diego, Ca
                    They should change the mitten hands on their pilots. I always paint them black so they are not so obvious.
                    • JamesonC
                      MRC fanboy
                      • 619
                      • Laurens, SC
                      Originally posted by Deegeedoo
                      Thank you Pat,
                      Rudy
                      I always thought people mounted these right on top of the servo. At least I thought that was what I had seen people do on Avantis. I have one I am gonna install on my FW Bae Hawk and didn't even think about putting it further down like that.
                      • MANFRED
                        • 299
                        • San Diego, Ca
                        Would be great if they would release a bunch of these in primer only, for those of us who like to customize.
                          • 8817
                          Nobody ever looks inside the cockpit of my planes to see what kind of hands the pilot has but when they do, Mario, the plumber and Bob, the Minion, have mitten hands. LOL
                          • Deegeedoo
                            RC Pilot Airplane
                            • 7
                            I think the farther away from the leverage point the better. On this L-39 the designer chose pretty well the best spot to mount the brace.
                            • urrl
                              • Oct 2013
                              • 506
                              Morning flights
                              • vduniec
                                Hobby Squawk Pilot
                                • 314
                                Did some visual upgrades to the L-39. Printed out the 3D cockpit files and used the instrument faces from the stock instrument panel decal. Painted the stock pilot’s helmet and mittens.
                                  • 5401
                                  Nice Vic. Looks good
                                  • vduniec
                                    Hobby Squawk Pilot
                                    • 314
                                    The aircraft I represented is actually called the L-159. The back seat is removed and has, I’m assuming, additional avionics in the back bay. I used thin aircraft plywood to create the cover seen on the actual aircraft
                                    • vduniec
                                      Hobby Squawk Pilot
                                      • 314
                                      Fashioned a HUD using thin aircraft ply and a material called Solyx. This stuff is a pretty good for HUD material. It’s transparent but also has a “prism” effect that reflects light at different colors depending on the angle viewed. Samples of this material can be purchased cheaply.
                                      • vduniec
                                        Hobby Squawk Pilot
                                        • 314
                                        The finished product!
                                        • James
                                          Administrator
                                          • Aug 2017
                                          • 1543
                                          Nice looking livery. Great job!
