  • PhantomNut
    • Sep 2018
    • 95
    • San Diego,CA
    I've got mine on a 4 second delay and haven't had a problem. I haven't used flaps for take off though. Maybe I'll take the flap delay off just in case.
    • DCORSAIR
      • 1918
      • Selma, Ca.
      Originally posted by Gremlin
      Three of us maidened our L-39's this morning. 1st maiden went a dream. I was up next. Took off with no problems, I came around downwind and raised the flaps and bam! All hell broke loose. It seems, one of my flaps stuck down and it rolled over and went into a spiral. I yanked hard and it pulled under in a loop. As I was climbing again, I managed to get some semblence of control back. I think the stuck flap went up as I was able to bring it around the circuit. My more experienced buddy was beside me and I was so shaken I handed it to him to land. Thankfully he did with no further problems. I am one lucky guy. My lovely L-39 almost died a horrible death after 30 seconds. Guess what? I had the the flaps on slowed/delayed deployment. Whats worse, I read earlier in this thread about a guy who had exactly the same problem. I noted it at the time, but had forgotten this when my L-39 arrived from MRC EU. So I thought I better post and strongly advise do not use delayed/slowed deployment on the flaps or you risk a stuck flap and horrible consequences. For later flights this morning, I turned off the delayed flap deployment and had had a few more flights which went sweet as a nut. In fact, its a real *****cat to fly with no real vices. It looks stunning in the air. Our third maiden went without incident.
      The strange and slightly worrying thing about the suspected slowed flap issue, is that it doesn't seem to happen on the ground. I'm thinking that the air pressure pushing against the flaps is maybe a prerequisite to replicating it. I will try to see if somehow I can replicate this on the ground.
      Thankfully, I'm sitting here remembering a good day's flying but it could have so easily been a completely different story.
      Mine did the exact same thing and I don't use a delay on the flaps, mine turned over on it's back right after I raised the flaps so I guess like yours, it stuck, I was able to roll it upright and climb a little but almost lost it several times until my brain said to cycle the flap switch and I did, it must have worked because it started flying normal with no issues, landed no problem, never did find the problem and went ahead and bypassed the board, it now has many flights with no issues...........:Sweating:LOL
      • Gremlin
        Blue Good, Green Bad
        • Dec 2018
        • 8
        • Ireland
        I only had mine on a 1 second delay. The delay may be a red herring. However I can say that when I took the delay off I had no further issue. Deploying the flaps without a delay using the recommended elevator mix did not cause any pitch change, so I dont see any reason to use the delay. I'm gonna test the hell out of this as my poor heart could not take another incident like that.
          • 8817
          This only seems to happen if the flaps are deployed and pulled back in during flight. If you don't use them for take off or try a slow and low pass with flaps (1/2 or full) and then suck them up, you may not see this. If you only use flaps for landing and then suck them back up on the ground or on the bench, they don't seem to exhibit this problem. I've cycled mine many times on the bench and rolling around on the ground and they've never stuck. Weird.
          • DCORSAIR
            • 1918
            • Selma, Ca.
            That is what I was doing, a slow pass with full flaps and gear down, as I went by I pulled the gear up and watched them go up then pulled the flaps up which are on a dial, with the roll of your finger they go right up or I can slow them down, but just maybe I rolled them to slow and one didn't go up as if I was using a delay, maybe?
              • 8817
              It's a mystery. Maybe a change to a different kind of servo for the flaps might resolve this.
              • Petronio
                • Dec 2017
                • 171
                I dont think the delay should have anything to do with the servo getting stuck..but I get scared reading about it.. I am just finishing mine today and it will be maidened in the coming days. I had added a 4 sec delay..quite like it for realism and functionality but now I dont know whether toI leave it or not. I have a delay on my A4 and flown it quite a lot with no problems at all so I dont think the delay is the issue...maybe just random. Oh well fingers crossed!
                  • 8817
                  A delay on the flaps alters the pulse signal to the servo and some servos may not like signals being fed to it that way. Like any electronic part, a servo is just a few circuits on a tiny board, with limiters and micro controllers. Even within the same batch, I think you can get variations of quality from one servo to another. Remember, it's usually just one, NOT both, servo that gets stuck and it's not even on all these planes. I would suggest that if you have it on a long delay, keep your finger on the flap switch and be prepared to deploy it again and be on the aileron stick to counter what a stuck flap will do.
                  • adb2@suddenlink.net
                    Advanced Pilot
                    • Nov 2018
                    • 104
                    • Abilene Texas
                    Why take a chance?
                    • Petronio
                      • Dec 2017
                      • 171
                      Decreased the delay to 2 sec :Whew:LOL
                      • Gremlin
                        • Dec 2018
                        • 8
                        • Ireland
                        But why have it at all? If you setup the recommended mix of down elevator there is no tendency to pitch up/down or balloon when the flaps are deployed at full speed, so what is the point in using the delay feature? If you increase the delay to a really long period you can see visually the flaps sorta stepping rather than moving slowly and smoothly. Try it for yourself and see. I can't say for sure that it was the cause of my stuck flap yesterday, but I certainly will not be taking the chance.
                        If you do insist on using the delay keep your flap finger ready to re-deploy quickly if you encounter any issue!
                          • 8817
                          There are reasons why and I've covered this in the past. Yes, I have tried. Stop and analyze the situation and you'll see why also. I won't bore everyone with it again.
                          • Ron1950
                            Retired ATC
                            • Oct 2015
                            • 887
                            • brandon ms
                            you guys are scaring me about the flaps lol. lights and flaps are the only thing I haven't y harnessed to the rx everything else seemed to just not work well in the blue box
                            • Chilly Bear
                              • Nov 2018
                              • 61
                              With asymmetrical extension slower would be better if you recognized it as such and recovered right away. One aileron "snapping" down and one staying up isn't very appealing. If it isn't working right it might decide not to work right at all variances of movement. I'm going to keep mine at 4 seconds until it misbehaves.
                              • seaviper
                                ATC retired
                                • Aug 2016
                                • 1092
                                • Philadelphia Mississippi
                                L-39's in the rain
                                • Quickstop
                                  • 275
                                  5 second delay on mine and never a problem. If I played it totally safe based on what I’ve read I’d never fly it at all
                                  • Flyboy48
                                    • Dec 2018
                                    I have seen a couple of posts about the 3D printed cockpit parts. It was stated that the parts would be made available for sale. I sent an E-mail to Motion and was informed that they will not be making them available for sale and to download the 3D files. What about us guys that don't have 3D printers or don't know someone who has one.
                                      Hi Flyboy48, welcome to Hobby Squawk! The Factory-Printed 3DPUPs for our recent aircraft have turned out to be very, very low demand, to the point that it constrains our ability to mass-produce them in the quantities (and speed) as we originally planned. But don't worry, we'll still have the L-39 cockpit set available on MotionRC.com for those of you who don't have access to 3D printers. There are some things behind the scenes but I'd estimate a few more weeks before the L-39 set is in stock. We'll post here when they're available.
                                      Interestingly, according to our download history, the free file downloads are outpacing the pre-printed purchases by about 50 to 1. It seems more of you have printers than we thought!
                                      • Petronio
                                        • Dec 2017
                                        • 171
                                        I have at least 4 mates who have a printer xd
                                        • BlueQ
                                          • 6
                                          • South Black Forest
                                          Unfortunately they don't live in Germany :Crying2:
