  • seaviper
    ATC retired
    • Aug 2016
    • 1092
    • Philadelphia Mississippi
    Originally posted by Ron1950
    I don't have a 3d printer so I make a few inquires as to anyone that will make me a nose gear support on here and on rcg.. not even a reply etc to any threads...I go on facebook and some nice guy in England says he wiii make me one and wont even take any money for shipping.. thanks
    For the L-39 or something else?
    BTW we got three L-39's in the club Ron. I just went over 3 hours on mine.
    • Ron1950
      Retired ATC
      • Oct 2015
      • 887
      • brandon ms
      nice I haven't even flown mine yet lol
      • Cdrop20
        Utahflyer
        • Nov 2018
        • 6
        • Gunnison,UT
        if you need anything 3D printed message me. I have a CR-10s. I only have PLA for material but I would be more than happy to help you get the parts you need.
          I can print you the nose strut support for the L-39 in ABS. Just let me know if you are interested.
          • PhantomNut
            • Sep 2018
            • 95
            • San Diego,CA
            If you would be able to print me one for my new L-39 I'd very much appreciate it and be willing to pay for it.
            • Ron1950
              Retired ATC
              • Oct 2015
              • 887
              • brandon ms
              thanks for the offer guys but have one getting shipped today
              • JamesonC
                MRC fanboy
                • 619
                • Laurens, SC
                Steve, there a a few different items on thingverse that I have been trying to find someone to print for various planes. Is this something you could do? Obviously willing to pay for all items, I just can't seem to find someone with a printer!
                  I could certainly give it a go for you. Just PM me.
                  • Felixs10
                    Felix S.
                    • 113
                    • Bergen county, NJ
                    Originally posted by Tom.MotionRC
                    Anyone in the USA who notified us about a missing gunpod will have the gunpod shipped today.
                    Got my gun pod today , Thank you !
                    • Dp123
                      DP go fly
                      • Jul 2018
                      • 12
                      • UK
                      We have tested every board we replaced and so far we have yet to find a bad one. The plane comes out of the box with the landing gear in the up position. I think the board is thrown out of sync when the plane is powered up for the very first time while the radio has the gear switch in the down position but the plane has the gear in the up position. Once it is brought back in sync via the above process, it appears to stay in sync. This is a new board for all of us. In the past, every new plane would receive a new control board. At this point, every new plane will either use this same MCB-E or the MCB-D so all of us will not have to lead a new control board for every new plane. We'll likely go back and swap these boards into existing planes and phase out the one off control boards.
                      Even after following the oft reposted procedure for re-syncing the gear sequence, I have still not been able to make mine work properly. So I have carried out some experiments using a stabilised power supply, and have discovered that the box only works correctly (i.e. nose gear steering only works with the gear down) when the input voltage is 4.7 to 5.0 volts. As soon as the voltage goes above 5.0, strange things start to happen with the nose gear steering and rudder outputs. I have 2 of the boxes, and was able to replicate these results on both. The effects of higher voltage input are different in each box, but both will only work correctly with 5.0 volts input. To me, this means that something in the box is very voltage sensitive when perhaps it shouldn’t be?
                      I have used a y lead on the rudder output to bypass the box, so for me, this is not a major issue, but hopefully my experiments may help to identify the source of the problem.
                      Would anybody else who has had this problem like to try my experiment for themselves, and see if it works for them?
                      regards,
                      Dave
                      • Cdrop20
                        Utahflyer
                        • Nov 2018
                        • 6
                        • Gunnison,UT
                        Thanks MRC for sharing the cockpit files. I don’t even have this plane yet and I’ve already detailed my cockpit and ordered my batteries. I can’t wait until the L39 is back in stock.
                        • PhantomNut
                          • Sep 2018
                          • 95
                          • San Diego,CA
                          Maidened my L-39 today and it flies great! 4 nice uneventful flights. A keeper!
                          • Marksj100
                            • Aug 2018
                            • 9
                            Ordered one from Motion EU to go with my Avanti;-)
                            • ChriKri
                              Pilot
                              • Nov 2018
                              • Germany
                              I assembled mine yesterday. It was really fun and everything fits perfect.
                              Unfortunately the left Elevator servo has an issue, it works not smooth. It “jumps” step by step to the positions. Verified without the board by a direct connection to a servo tester.
                              I already opened a case for this, hopefully they solve it as fast as they solved my ticket for the missing gun pod ...
                              • adb2@suddenlink.net
                                Advanced Pilot
                                • Nov 2018
                                • 104
                                • Abilene Texas
                                regards,
                                Dave
                                I had this same problem which I solved by changing receivers.
                                • BlueQ
                                  • 6
                                  • South Black Forest
                                  Hello guys, can anybody tell me, where the eagle a3 gyro may be positioned? Has it to sit just in the roll axis or may it sit aside ? The manual says nothing about that and i'm not sure. How far may it be in front of the cg ? I've surching a picture here for your solutions but no luck. Thanks a lot for answering,
                                  regards,
                                  Rudi
                                  • PhantomNut
                                    • Sep 2018
                                    • 95
                                    • San Diego,CA
                                    My rudder servo did the same thing. Replaced with a hitec and all is good.
                                    • Gremlin
                                      Blue Good, Green Bad
                                      • Dec 2018
                                      • 8
                                      • Ireland
                                      Three of us maidened our L-39's this morning. 1st maiden went a dream. I was up next. Took off with no problems, I came around downwind and raised the flaps and bam! All hell broke loose. It seems, one of my flaps stuck down and it rolled over and went into a spiral. I yanked hard and it pulled under in a loop. As I was climbing again, I managed to get some semblence of control back. I think the stuck flap went up as I was able to bring it around the circuit. My more experienced buddy was beside me and I was so shaken I handed it to him to land. Thankfully he did with no further problems. I am one lucky guy. My lovely L-39 almost died a horrible death after 30 seconds. Guess what? I had the the flaps on slowed/delayed deployment. Whats worse, I read earlier in this thread about a guy who had exactly the same problem. I noted it at the time, but had forgotten this when my L-39 arrived from MRC EU. So I thought I better post and strongly advise do not use delayed/slowed deployment on the flaps or you risk a stuck flap and horrible consequences. For later flights this morning, I turned off the delayed flap deployment and had had a few more flights which went sweet as a nut. In fact, its a real *****cat to fly with no real vices. It looks stunning in the air. Our third maiden went without incident.
                                      The strange and slightly worrying thing about the suspected slowed flap issue, is that it doesn't seem to happen on the ground. I'm thinking that the air pressure pushing against the flaps is maybe a prerequisite to replicating it. I will try to see if somehow I can replicate this on the ground.
                                      Thankfully, I'm sitting here remembering a good day's flying but it could have so easily been a completely different story.
                                        • 8817
                                        My flaps did the same thing. At 4 second deployment, one flap stayed deployed after take off. I immediately lowered the flaps again to stabilize the plane. Flew it one circuit and landed. Changed to 3 seconds, same thing. Then changed to 2 seconds and it didn't do it. I've even hooked the flaps directly to the RX before any of this happened. I'll keep them at 2 seconds until it acts up again.
                                        • Chilly Bear
                                          • Nov 2018
                                          • 61
                                          Mine have always been set to 4 seconds and I haven't had a problem so far. I have always used flaps taking off. I'm adding this as I didn't see the issue was after taking off with flaps for some. I'm using an AR660T.
                                          Last edited by Chilly Bear; Dec 11, 2018, 04:30 AM. Reason: added flap for takeoff comment
