I found when installing the wing tanks it sure was easy, because of the tight fit, for them to become unplugged.
I thought about that so I tested them at the wing board and they worked fine. Anyhow for some reason they work now when the gear is down ????. Still may plug them in to stay onComment
They only work when the gear is down for landing. At least on mine that is the way they work.Comment
I believe these boards use one or two common grounds for everything. Yours may have had poor contact on some of the plug pins. I had that on an early version of these boards and by unplugging each one and wiggling them vigorously back on, stuff that didn't work started to work. Poor pin contact can be a random, on/off sort of thing.Comment
Stuart is here to show you how you can keep the landing lights on all the time for your new Freewing L-39 Albatros and goes for a tandem flight. Product page...Comment
Owe an update here after having been flying the Albatros for the past weeks. That the flight is absolutely delicious we already know from all the positive feedback from the guys, even that it is efficient but did not expect it to be to this extent. The past days we have been flying the Albatross perfectly at around 35 / 40% throttle stick, cruising around comfortably and even at a very reasonable speed squeezing up to 6min out of the stock setup..what and amazing flier and how aerodinamic the design is. Yet to see it stall too... Initially I had my timer set at 3min but ultimately after taxiing back my radio shows -3min with a voltage of 3.80V per cell. I could still squeeze it up to more than 6min I am sure. Kudos Motionrc & Freewing!Comment
Thank you Pat,It was already done. ;)
https://www.thingiverse.com/thing:3134218
I've already printed one and installed it. Works perfectly!
I think that is a very smart idea. There is no one near who has a 3D printer so I'll make one out off aircraft plywood.
Rudy1 PhotoComment
I always thought people mounted these right on top of the servo. At least I thought that was what I had seen people do on Avantis. I have one I am gonna install on my FW Bae Hawk and didn't even think about putting it further down like that.Comment
I think the farther away from the leverage point the better. On this L-39 the designer chose pretty well the best spot to mount the brace.Comment
Morning flightsI felt more comfortable with the L-39 but hopefully the F-22 will feel just as good after a few more control surface adjustments.Comment
Fashioned a HUD using thin aircraft ply and a material called Solyx. This stuff is a pretty good for HUD material. It’s transparent but also has a “prism” effect that reflects light at different colors depending on the angle viewed. Samples of this material can be purchased cheaply.2 PhotosComment
