Thanks. I agree. Except for these last few whistle videos I usually hang around full throttle anyway for loops, verticals, etc.
My first ever flights in Jacksonville. I'll be here about 6 weeks. Great field.I think I over did it installing the six Nerf football whistles in the F-15; I might stop up some of the intake whistles. I love the whistles in the F-16 tho...Comment
Morning flights.Swapped whistle into air intake of F-16 from F-15, cutting the whistle length for a higher pitch in F-16. I may move another whistle from intake of F-15 late...Comment
Shortened an intake whistle for higher pitched sound.I cut the length of one of the installed Nerf Vortex intake whistles for a more higher pitched sound. Three Nerf Vortex whistles are installed into the fan c...Comment
I like it. Sounds better with the higher pitch. Do you think placement in the intakes works better than the outlets? I have a Vortex on the way to play with the whistles on my 90mm F-16 but I am running a JP 8S fan which has a rather high pitch whistle to it already. Sounds awesome like it is but I figured I could do some experimenting of my own even so. BTW, I like the owl mascots better than the possum. Sorry they have vacated but maybe they will be back.Comment
The owls did not vacate; I did. The flights you see are from Jacksonville; not Weston's Markham park where the owls are. I will be spending about 5 more weeks in Jacksonville.And no I didn't intend to scrape the runway on that low pass...Comment
Roy's Israeli theme paintRoy did an outstanding job repainting his F-15 using Tamaya acrylic paints. Looks as good as factory paint. Maybe I could talk him into doing mine in US camo...Comment
Is there a chart posted somewhere that shows the hook up placements for the LG & light sequencers...nothing in the manual or on the website that I can find to hook everything up properly.www.TSHobbies.com
Hobby Paint racks and acrylic display stands for collectibles.Comment
I just ordered up an F-15 with the 8S power set up. I'm very anxious to get this bird in the air. After reading the blog and looking at pics I just couldn't resist. Does anyone have any helpful tricks/tips they would like to share?Comment
I got the plane on Wednesday evening 7/20. The install of the motor, ESC, BEC, Gyro, Receiver, and the batteries wet well. Getting everything trimmed and working as I wanted it to took a bit longer that I had allowed for.
The Maiden went will with the local EDF Guy (Phil) at Apollo Field. Man that 8 cell setup can climb. Take off was smooth and very scale looking. First flight was all about the trim. Second flight was all about the Gyro. Yes you guessed it the third flight was all about practicing approaches for better landings. I was able to get two more flights in on Sunday.
The plane is great in the air and well behaved on the ground. The build up video was very helpful as were the blog posts. I took some pic's but they are still in the camera. I'll post them soon.
Great Job MRC. This is another home run. Not sure which plane I like best. The new F-15 or the P-38. I just can't get enough of either of them.Comment
Thank you urrl for all the great videos. I'm going to be practicing your landing technique. I normally do an Airforce approach. Just because it looks cool. With that said the shorter, Navy approach works much better. I'm heading out to the field later today. I'm going to practice on the sim a bit and see how it works at the field.
I also like your owl mascot. We have a falcon and a couple of Hawks that like to hang around Apollo Field.Comment
I'm back flying in Weston FloridaComment
Doug and I flew our F-15 jets this morning. He let me borrow his spare inrunner and I installed it. Here I take it through the paces. I came away with the im...Comment
urrl: have you ever experimented with ESC settings on your 15? or other planes?Lon
Freewing A-10 80mm, F-86 80mm, F-15 90mm, F-16 90mm. Avanti. FMS DHC-2 Beaver, Fliteline P-38L ,HSD HME-262, HSD F86.Comment
