Originally posted by dusmmdb
View Post
Official Freewing 90mm F-15C Eagle Thread
Don't be!! It was a 10 hour round trip to get there!! This was just for an electric event that they were having that weekend. Not my usual field...Check me out on youtube at https://www.youtube.com/user/gooniac33
I'm fortunate that I have two nice flying sites within 15 minutes of the house. One has an 800 x 60 foot paved runway, the other has a 450 x 45 foot geotex runway. I typically have only flown my larger jets at the bigger field, but I did fly my F-15 and F-14 at the smaller field last weekend finally with no issues.Pat
I am lucky now too because I have one within 20 mins of me now too. I can fly all of my stuff there with no issues. This was an event that we wanted to attend though and glad I did! Nice to see that my lil ole EDFs can still wow the crowd that is used to turbines!Originally posted by crxmanpat View PostI'm fortunate that I have two nice flying sites within 15 minutes of the house. One has an 800 x 60 foot paved runway, the other has a 450 x 45 foot geotex runway. I typically have only flown my larger jets at the bigger field, but I did fly my F-15 and F-14 at the smaller field last weekend finally with no issues.Check me out on youtube at https://www.youtube.com/user/gooniac33
yep...goes in a slot right behind the canopy latch. You can see capt Mike gluing it on in the build video. I have been really watching this one for a while now, and just about ready to pull the trigger...one question though. Should I pop on the inrunner version, or wait for the arf plus to come back in stock, and go for an 8s set up ? Any suggestions are welcome.
Gooniac, urrrl and DougV all seem to like the 6s inrunner. I like mine on 8. Different strokes for different folks.
I went with 8 because I had the JF 90 laying around doing nothing.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
Same here figured I'd put that JF 90 to work; Otherwise I just would have gone stock.Originally posted by bill34207 View PostGooniac, urrrl and DougV all seem to like the 6s inrunner. I like mine on 8. Different strokes for different folks.
Mike\"When Inverted Down Is Up And Up Is Expensive\"
I'd say go with the inrunner. Just don't rely on a 5000 ma pack for it (even the stock outrunner is hard on packs) Most of the ones I mentioned are flying 5800 to 6200 packs in them.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8w
Thanks.... i guess I have to cut the slot...mine appears to be glued over... but.... mystery solvedOriginally posted by scooter genie View Postyep...goes in a slot right behind the canopy latch. You can see capt Mike gluing it on in the build video. I have been really watching this one for a while now, and just about ready to pull the trigger...one question though. Should I pop on the inrunner version, or wait for the arf plus to come back in stock, and go for an 8s set up ? Any suggestions are welcome.
on the 8s vs 6s... I am perfectly happy wth the HV setup in terms of power... but even with a 6000mah battery I have to start my landing approach at 3;30.... or down she comes. My fl CG is ok since I removed weights from the nose cone
i would be curious if 8s can provide a longer flight time.
Actually, if you watch the build video, at 16:45 he is gluing that piece in a slot that appears to be in the latch mechanism plastic.Originally posted by Corey Thunes View Post
That piece is probably some sort of antenna that glues onto the top of the plane. Look for a slot on top of the jet.
I know you've already installed it, but that antenna actually goes under the nose, about 2" back from the nose cone. It doesn't show a step for that in the manual, but if you look at the page where you glue the probes on the sides of the fuse, you can see the antenna installed on the bottom. I have to make sure that when I transport the plane I support the nose ahead of the antenna to keep it from being bent/torn off.Pat
.png)
