    I tried to find an FMS equivalent to the 1850kv EDF but none is listed.
    My FMS "Pro" fans arrived today and they were so easy to just drop in. Will test them out in a couple of days. The Pro fan is supposed to put out ~2500g of static thrust. Does anyone know what the static thrust of the stock fan is? I'm wondering if they'll be of any benefit to drop them into my FW SU-35.
    I could never find any stats on the E-Flite Fans to compare with. What I can tell you is those stock fans together drew maximum about 118.7 Amps and 2810 Watts. The FMS Pro fans drew (using the same battery) 148.4 Amps and 3640 Watts, which is about 28% more. The difference in take-off distance on grass and it's vertical performance was so dramatic, that it seems like even more than 28% increase in thrust, but would like to learn what the real numbers are.
  • Tabdy
    Thanks. Despite some brief reading in Wikapedia I hadn't realised that. All the same I hope new models aren't being restricted by a need to remain within a 6 channel limit.
  • KevinMar
    Originally posted by Tabdy
    The SU30 should have flaps, canard and thrust vectoring to be true to scale.
    Not all versions of the SU-30 have thrust vectoring and/ or canards. In fact, the only versions that have thrust vectoring and canards are the new MKI and SM family of models. The whole Flanker family is a complicated clusterfudge of different variants that are nearly impossible to keep track of.
  • Tabdy
    The SU30 should have flaps, canard and thrust vectoring to be true to scale. I therefore consider it very overpriced. Its a shame the manufacturers seem to be constantly catering towards the beginner with beginner equipment. Some, or maybe many, of us will upgrade when necessary and prefer the larger and more sophisticated aircraft with all the benefits which go with them.
  • Rcfiddy1
    Originally posted by radfordc
    You had your battery all the way forward and added some more weight? Doesn't compute!
    I still have foil tape in exhaust tube when I had afterburners but since removed them. Plus my zeee 4000mah batteries weight 599g. I needed to add weight along front fuse to get CoG at 150. Are you running the fms fans also?
  • radfordc
    My CG is here with batt all the way to the rear. Click image for larger version
ID:	319159Click image for larger version
  • radfordc
    Originally posted by Rcfiddy1
    After looking at marks i was at 150mm for CoG….Probably why I loked it so much.
  • Rcfiddy1
    After looking at marks i was at 150mm for CoG….Probably why I liked it so much.
  • radfordc
    To use the vernacular...with dual batteries and FMS fans she flies like a striped a** ape! Click image for larger version
Name:	striped ass ape.jpg
  • radfordc
    Ok, so after I mothballed this plane last year for being a slug I decided to upgrade to fms motors and 2 battery setup. Running 2-4000 mah batteries with front battery all the way forward I still needed to add a bit of weight up front to get CoG at 130. But what a world of difference. I think might be one of my favorites now. Short hat cam.
    https://youtu.be/3za624-qRfI
    I'm with Hugh...get the CG back to 145-155 and you will enjoy the plane more. I put the front battery as far back in the battery compartment as possible and that gives about 145mm for CG.
    Outstanding, I'm with you on the fan upgrade. Although I'm still using 1 SMC 5300, getting only 3:10, and tried an SMC 6200 and upped it to 3:40. Just a thought, but for me I like the way it flies at the aft end of the CG range, at 150 to 155 mm. Seems to get the nose up easily for landing there, so you may want to try it with less nose weight.
  • Rcfiddy1
  • radfordc
    Hugh, I'm not using ailerons...tailerons only. The surfaces on the wing are flaps only.
    ​only.
    radfordc, Outstanding Charles, looks like you have the ideal setup now. 4 1/2 to 6 minutes on this bird is really special. Kudos to you for rigging it the way it should have come from the beginning! I seem to remember you said that you are at 125% on the ailerons, correct? Looks like your roll rate is very quick, the way it should be. You've got it flying like that airframe was intended to perform! Great videos as well, all around looks like it was a beautiful day.
  • radfordc
    Several more fun flights with the Su-30 on dual batteries.
    First flight was 4 minutes of speed and acro... https://youtu.be/0_DAgNnEFyM
    Second flight was 6 minutes of straight and level cruising.... https://youtu.be/Qg-xC-gNxwk
  • bandetx
    I installed the fms fans and the v3 cyclone power afterburners
     - Easy to Install & Set Up.- Suitable For Freewing , FMS & E-flite 70mm EDF With Inrunner Motor .- Suitable For Other 70mm EDF with 29mm - 30mm Diameter Inrunner Motor.   - With Super Bright 21W LED CenterBurner Light Bar- With Y Cable , 4s & 6s Batter
    Performance is much better! The added weight to the tail helps the natural nose heaviness of the plane. It rotated off the runway in about half the time and the pitch is a lot more responsive in the air.
    For the moment I don't plan on doing the 2x battery mod because I don't want to buy 2 more batteries...
  • radfordc
    The two 4000s weight 1190 grams total. But, I can maintain the CG at 150mm with no additional weight in the tail beyond the stock weigh that comes installed originally. The total flying weight of the plane is 10.5 lbs. That seems very heavy compared to the original stock configuration with one 5000 battery. But the plane doesn't fly "heavy"...it flys fast and when you pull nose up it climbs with authority. Yes, the new FMS fans provide more punch; but I think having each fan motor on a separate 6s battery prevents the voltage sag caused by trying to draw 120-150 amps from one battery. I'm flying at 50% throttle for most of the flight except when going vertical...ie, steep climbs, loops, cuban 8s, etc. I haven't tried the slow, high AoA, "Harrier" type stuff and this plane may not excel at that. My Su-35 does that sort of stuff real well....of course it flys about 3-4 pounds less weight.
    I flew 4:30 this morning and the batteries were at 30 percent.
    Outstanding, what is the total weight of the 2 4000 mah batteries you are using. I ask this, because I've got several SMC 8100 mah 20 C batteries (which test out to 22C, which is higher than a RT 70C/HRB 50C/Admiral 50C) that weigh in at 903 gr that I use in my F-16 which has the 12 blade inrunner in it. On that, I get 5 minutes of flight time and was thinking of trying it in the SU-30. The only down side is the extra weight (all in the nose) moving the CG from 150 mm to something like 120 mm. For you having 1/2 your battery weight in the speed brake compartment closer to the balance point has to make it much easier to get the CG where you want it.
