    From what I've found, this scheme was just introduced in December 2019.
    • Miroslav Cerny
      • 42
      Will you spray new camouflage? Then add a photo
      • Quickstop
        • 275
        If you want to get really picky I believe the new splinter camouflage scheme is only on the newest E model grippens. Personally I’m not that picky if it looks good put it on.
        • Miroslav Cerny
          • 42
          That's not it. This color fits me. They couldn't have chosen better.
            True that it's only on the E model, but it will still look good on this one.
            I will totally primer and repaint and get decals from Callie.
            • Miroslav Cerny
              • 42
              I'm still looking for a visual difference, between version C and E. At first glance, I do not recognize ...
                • 2137
                • On planet earth....right
                I'll be installing thrust vectoring from the get-go on the Gripen. Hopefully there will be a pre-order, hint...hint. After watching the live stream recording just now, I noticed the tailcone/nozzle was said to be foam compared to the plastic on the non-TV tail. That's beneficial for weight savings, which is excellent, and the downside in this case is that it looks less realistic compared to the plastic nozzle. I notice the petals on the nozzles look different from each other (I'm not talking about the whole tail piece looking different as that's a given since it has TV). Ha-ha
                Click image for larger version  Name:	20200904_135511.jpg Views:	0 Size:	67.8 KB ID:	272758Click image for larger version  Name:	20200904_135530.jpg Views:	0 Size:	69.7 KB ID:	272759
                • Reaper911
                  • 89
                  • Winterpeg, Canada
                  Originally posted by Miroslav Cerny
                  Interesting camouflage. Reminiscent of the SU-35 ... I like that
                  This is nice too
                    Most of the changes from the C seem to be internal (different engine, more fuel capacity, upgraded radar). One external difference is the E has 2 additional hardpoints for weapons/equipment.
                      This is probably the most significant exterior difference between the C and E.
                        I'll be free-drafting a few 3DPUPs for the Gripen on my livestream in an hour from now (9pm EST). BOL, MICA, pylons, and other assorted bits for the Gripen, as well as tank parts, MiG-29 greeblies, etc.
                          • 5385
                          Alpha, any word on what’s happening with the MiGs TVs?
                            We've decided that we're going to make it available in the same format as the Gripen, since most people seem to prefer it that way. Factory molded/painted, servos pre-installed, drop-in installation.
                            More info to follow.
                              • 5385
                              That sounds great. Of course that leads to one more question. Assuming it won’t be available when the MiG arrives it’ll be something we can graft in after we’ve built and flown the MiG, correct? Not like the Gripen where it would take surgery since the carbon spars are glued in.
                              • Pogo
                                • 452
                                • Waterford, Ontario, Canada
                                Looks like they've also gone to a single nose wheel with maybe a larger diameter (?). Might you be making a printed version of that scoop at the base of the vert. tail, Pat?
                                Tom Click image for larger version
                                • Gravythe clown
                                  • Mar 2019
                                  • 711
                                  • Clovis, California
                                  I guess that’s the grown up pilots Gripen. Training wheel removed. 🤣
                                  Gravy
                                  • Airguardian
                                    Post Stall Svengali
                                    • Aug 2020
                                    • 1664
                                    • Catalonia
                                    The two wheel nose gear is the E version.
                                      Did you mean to say C version? C has the twin nose, E has a single.
                                      • Pogo
                                        • 452
                                        Gravy
                                        Tom
                                        P.S. I think the chem-trail dispensers are different too
                                        • kallend
                                          • 1857
                                          I 3d printed overlays for the TV nozzles on my Eurofighters. Very thin, hardly added any weight but looked much better.
