what do you think about having gyro on the canards, it will be difficult to get it on all rudders, without a flight controller?
Hi Alpha,Originally posted by Alpha View Post
any chance you could make them available as a download from the support page? I must admit I wasn't able to watch the stream yet (middle of the night here in Germany) and I was busy with my family during the day. My abilities as a designer are far from the level of a real pro as well...
Best regards,
Jens
I think you want the gyro on the control surface with the most aurthority and the most sensitive. In this case, it would be the elevons. "Rudder" is the least sensitive control surface in terms of gyro compensation. Just take a look at any typical gyro. The control surface that requires the most attention for a gyro (and the least amount of gyro gain) is AIL, then the next is ELE. Rudder can take the most gain without over-compensation (oscillation). On an elevon plane like this, if you put the gyro on the delta wing control surface, you've got both compensation for AIL and ELE.Originally posted by Anders Boström View Postwhat do you think about having gyro on the canards, it will be difficult to get it on all rudders, without a flight controller?
PS. What do you mean by "all rudders"? The Gripen has only 1 rudder. And even if you are talking about gyro compensation for when you add TV nozzles, the rudder component of the TV nozzles is typically "Y'd" to the main vertical rudder, which means it's still ONE rudder.
I see. In any case, if you use a gyro, it's only necessarily to control the elevons on this plane. The actually vertical rudder is a bonus and can easily be connected to the rudder channel of the gyro. Even the cheapest, simplest gyro like the HobbyEagle A3-L and be used and set for "elevon" and it'll do the mixing for you. I've used it on a Mirage (elevon plane) and also something similar on an Opterra wing.Originally posted by Anders Boström View Post
Exactly, we call it heightrudder, skewedrudder and siderudder, if you translate. 👍😀
On a plane like this Gripen, there is no need to gyro control the canards.
So you're a fighter, now there's no woman living in my apartment, and model airplanes are hanging out in the living room and lounge.Originally posted by Anders Boström View PostMust show the wallpaper in my living room and yes no woman lives in the house! 😁
When a girlfriend comes, she doesn't believe her eyes ...
- Likes 2
Yup, this is clearly a pilot that has come to the point of flying solo :POriginally posted by Gravythe clown View PostI guess that’s the grown up pilots Gripen. Training wheel removed. 🤣
GravyFreewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
- Likes 4
Definitely agree that the elevons should be the primary, secondary and third priority - at least.Originally posted by xviper View PostI see. In any case, if you use a gyro, it's only necessarily to control the elevons on this plane. The actually vertical rudder is a bonus and can easily be connected to the rudder channel of the gyro. Even the cheapest, simplest gyro like the HobbyEagle A3-L and be used and set for "elevon" and it'll do the mixing for you. I've used it on a Mirage (elevon plane) and also something similar on an Opterra wing.
But definitely a bonus to get rudder and canards stabilized as well.
Overall not that difficult, just a matter of choosing a sensible gyro system with sufficient number of channels.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Finally hit the preorder button and hopefully its here around halloween. I had sold off all my older stuff, su35, avanti, the big eflite cessna 150, and f86 thinking that is was going to make some room in my workshop. Ha! I ended up replacing those spot with a freewing f14, the new mig29, and with the convincing of my wife for me to just get the gripen, that now too.🥳 Thanks motion for secretly calling my wife and talking about the importance of having a hanger full of awesome planes.
- Likes 3
I'm glad I'm not the only fool in the world ...Originally posted by Colorc View PostFinally hit the preorder button and hopefully its here around halloween. I had sold off all my older stuff, su35, avanti, the big eflite cessna 150, and f86 thinking that is was going to make some room in my workshop. Ha! I ended up replacing those spot with a freewing f14, the new mig29, and with the convincing of my wife for me to just get the gripen, that now too.🥳 Thanks motion for secretly calling my wife and talking about the importance of having a hanger full of awesome planes.
Great video! But I’m sure glad they don’t sound like that anymoreOriginally posted by Airguardian View Post
Hell yes. It even justifies the highly debatable music taste Jandro tends to cover it up with lolOriginally posted by Quickstop View Post
But it is the sound of flight time - unfortunately.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
