That's it. This is not an old stock setup, but an 8S system running a WeMo Midi Pro (6 blades) with a 1600kv HET motor.
With such a combo I can make the kind of constant energy-bleed aerobatics you see in these videos for 3 to 3.5min with a decent thrust-to-weight ratio (not 1:1 but close enough).
Alternatively, I can chill out and fly for 5 or 6 min with no issue. You don't get that kind of performance easily on any stock setup exceeding 9 blades.
The Hornet 90mm high performance EDF setup gets close though, but it's a different jet so not entirely comparable.
