  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1676
    • Catalonia
    Well, thanks!
    6 min is actually pretty short if we consider the length of my average video though, hahaha!
    • Thoemse
      • Sep 2020
      • 6
      Nevermind that crash at the end...
      Nice flights! (cept the crash :) ). You got a lot of experience with the su 35 and now with this one with TV.
      Wich one do you prefer if you had to choose one?
      I am torn between those:
      Pro Su 35: Cheaper and looks extremely nice.
      Con: Sounds horrible, made of light but crappy material
      Pro Gripen: Sound better. Probably longer flight time?
      Con: Tends to wiggle around a bit. Costs more.
      I know they're both very good jets but I don't plan to buy both. My hobby cellar is full with planes as it is. :D
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1676
        • Catalonia
        Thanks!
        Su-35. It's barely even a contest. (IMO)
        That's correct.
        That's incorrect. Sound depends mostly on the fans, and the stock fans are doodoo. Get the ARF and install your own stuff. With FMS Pro 1900kv fans with HW 80A Skywalker ESCs you'll get great performance and sound on the Su.
        Crappy material? Certainly not. If you ask me, the old EPS used in the Su-35 is widely superior to all the EPO crap we have nowadays.
        Yes, EPO doesn't get dinged and scratched as easily but it's extremely heavy, not really rigid, thicker walls need to me made to compensate for that, the planes that come as a result are underpowered pigs for the most part and it doesn't stick with epoxy, which is my favourite glue for structural repairs. So no, certainly not crappy. EPS is extremely light while still providing awesome mechanical properties. It's sad to see it being abandoned as a material, if you ask me.
        Sound mostly depends on your fan, again. And I certainly wouldn't recommend the stock setup either so this point is moot.
        Longer flight times? Not by any chance if you intend to improve Gripen performance. The stock bird flies about as long as the usual Su-35 setup. But if you go to more powerful Gripen setups, flight time suffers much more. Su-35 kicks the Gripen's ass in endurance any day. It also is a more efficient design as far as gliding goes. The Gripen is a brick.
        Also correct.
        But the real Gripen pros are:
        Has the easiest to handle high-alpha features, extremely easy to land, easier to upgrade to 8S, takes quite a beating during crashes (SU-35 gets the intakes crushed, but Gripen has them sideways so it has better survivability), etc.
        Both are fantastic aircraft and I recommend them both... but if you need to choose between them, for me, the Su-35 is the superior aircraft in most regards.
        As far as Su-35 sounds with the FMS 1900kv... check it out:
        • Thoemse
          • Sep 2020
          • 6
          So much helpful information in that post. Thank you very much!
          • paulrkytek
            • Jun 2019
            • 530
            • North of England
            I installed the fms 1900kv fans in my SU35 over a year ago, sound good, perform well. I looked at the gripen but decided against it as I already had the SU35. I bought my SU35 by buying the parts and adding my own servos, fans, escs etc, worked out about the same as buying plug and play but with better components so if you are happy to `modify` to achieve the best results then SU35 is a good option.
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1676
              • Catalonia
              Glad to help!
              • Airguardian
                Post Stall Svengali
                • Aug 2020
                • 1676
                • Catalonia
                • Naveda08
                  • Dec 2021
                  • 38
                  • New York
                  Maiden flight
                  • Airguardian
                    Post Stall Svengali
                    • Aug 2020
                    • 1676
                    • Catalonia
                    Congrats Naveda!
                    Welcome to the Gripen guru Club! :D
                    And Merry Xmas everyone!
                    Here's my special Christmas-edition video of the mighty flying-christmas-tree we all love ^^
                    • JLambCWU
                      • 267
                      Let’s Get HIGH ALPHA and LOW
                      With the 80mm Gripen from Motion RC and Freewing.
                      TURN IT UP 🔊
                        • 8814
                        TURN IT UP 🔊
                        https://youtu.be/Q3TTII8MxrQ
                        VERY artistic and well done. The snow in the background is a nice touch.
                        • kallend
                          • 1877
                          TURN IT UP 🔊
                          Very nice, but it needs an afterburner.
                          • Gary S.
                            • Apr 2020
                            • 52
                            • Fort Worth, TX
                            My Gripen has had a great life and was already highly modded. So I was switching all my TX RX over to FrSky X20s and....well I decided to go from 80mm 8s to 10s 90mm. (lots more modding) Just had my first 6 test flights and decided to do as speed check because its moving really fast....
                              • 5401
                              Very impressive, Both the mods and your results.
                              • Gary S.
                                • Apr 2020
                                • 52
                                • Fort Worth, TX
                                Evan, That is a tremendous compliment. As you are one of my great modding heroes/ inspirations. TY
                                • Gary S.
                                  • Apr 2020
                                  • 52
                                  • Fort Worth, TX
                                  • Gary S.
                                    • Apr 2020
                                    • 52
                                    • Fort Worth, TX
                                    • Airguardian
                                      Post Stall Svengali
                                      • Aug 2020
                                      • 1676
                                      • Catalonia
                                      Always thought FW should have made this a 90mm bird from the get go :)
                                      Great job!
                                      New Heavy Metal Gripen video just posted!
                                      • Crippe1991
                                        • Dec 2021
                                        • 4
                                        • Sweden
                                        Hi I have a question about the TV for the Gripen. To install it do I need to buy servo extensions or is the TV a pnp upgrade?
                                          • 5401
                                          PNP...
