All-New Freewing PJ50 Twin 70mm EDF Jet - Official Thread
  • avanti127
    I am going with the classy look.
  • GliderGuy
    Originally posted by avanti127 View Post
    No different than the AL37 ESC location and never had an issue. Plus they said it was tested for almost year in hot climates.
    Details of the testing are unknown, but I'm glad to hear that.
    However, the points of my post were #1, FACT: I had an ESC stop working/shut down during a hot day ground run w/o any cooling air flow (stupid of me). and #2 FACT: Any electronics will last longer if you take care to keep the operating temperature down.
    What I can state is that making a lot of flights on hot days with very little down time between flights AND all this flying has been done with cooling the ESC with the external PC case fan while the battery is being changed has given me good results (i.e., no more ESC failures). I prefer to have the maximum amount of margin possible.
    Bottom line, if you're gonna get the PJ50 AND you fly in hot climates AND you do a lot of flights with little cool-down time between flights....you have another data point to reference.
  • avanti127
    Originally posted by GliderGuy View Post
    Something to consider (possibly overkill depending upon your flying style and typical flying air temperatures)...
    (Photo below) I see that the ESCs are mounted in the rear tail cone. Thus, as with the AL37, cooling air only flows over them when the jet is in motion.
    This design leads to a few things which you may be getting prepared for....as learned from my AL37 (summertime days get HOT here)::
    1. Running down the batteries while stationary isn't a good idea. The ESCs get hot and heat is problematic for electronics. They'll last longer if you keep them cooler.
    2. If you must run down the batteries while on the ground, get some cooling air flowing into the ESC compartment.
    3. I built a cooling fan from a high volume/rpm, 24-volt DC PC case fan attached to one end of an old 6S battery and added a switch.
    4. The AL37 sits low enough so I place this cooling fan+battery assembly on the ground under the AL37 and blow air up onto the ESCs.
    5. Since typically I strive for a short down time between flights...as soon as the AL37 lands and taxis back, I put the cooling fan assembly under the bird and begin blowing air over the ESCs while I change the battery.
    I see that the PJ50 ESC compartment is high up and located on the underside of the tail cone. This will require building a small shelf for the fan+battery assembly to get the assembly high enough off the ground to effectively blow cooling air into the ESC compartment.
    Alternatively, when the bird arrives, I am going to evaluate this area and determine whether or not there is sufficient room to mount a small cooling fan in there that will be circulating air any time the main battery is connected. DC fans don't draw much current at all.
    Overkill....possibly. But electronics are happier when they are cooler. And, I have had an ESC shut down on me due to overheating while running down batteries on the ground when I could not fly off the charge.
    Screen capture from the announcement video...
Name:	Screenshot 2021-12-11 083633.jpg
  • avanti127
    Originally posted by mshagg View Post
    This thing is going to be a rocket and will sell like hotcakes. I think they've read the room brilliantly. Great job guys.
    There's a decade long back catalogue of military EDFs for people to work through.
    As for pricing, I heard the US is nudging 7% inflation? And you're gonna benchmark price against planes released years ago? Come on.
    I agree with you. The market is pretty saturated with Military aircraft and it's about time we get civilian jets into the mix.
    Yes, the "other" contender...
  • Bajora
  • GliderGuy
    People actually do that? I can see doing it momentarily for watt and amp measurements but just running it to drain the batteries down? I just take them home and put them on the dis-charger OR drive them up and down the runway a couple of times.
    Ummm….Yes.
    Consider 4 min of runtime on the ground at cruise power vs sometimes hours on a discharger vs who knows how many trips up and down a runway at taxi power (a lot of taxing…more than a few trips) to use 60% to 70% of a 6000 mAh cell and reach the recommended 3.8 V storage voltage. Assuming a 10 amp draw at taxi power = almost half an hour of taxi trips (just a guess = 10 A). And I have 10 batteries to discharge if the weather turns bad.
    I’ve done it and learned it isn’t a good idea when the ESC shut down. If I do it now, I supply cooling airflow to the ESCs on birds that don’t have the ESC mounted in the engine airflow stream or propwash stream.
    Call it….Lessons learned and passed along for the edification of others.
    Best way….Use the MiG-29!!! 2 batteries at a time and ESCs mounted in the fan’s airflow stream. 10 batteries discharged in 20 min without any ESC overheating concerns.
  • GliderGuy
    Originally posted by ridgerunner View Post
    So if the AL-37 is a Boeing 737 Max, (nod, nod, wink, wink), what is the PJ-50?
    Cessna? Lear?
    A close match…
    Click image for larger version  Name:	EDFA94BA-9F3E-427C-BD05-5FC3245BE54A.jpeg Views:	0 Size:	75.8 KB ID:	332256
  • Gilatrout
    Cessna? Lear?
    Gulfstream
  • ridgerunner
    Cessna? Lear?
  • GliderGuy
  • BigJim
    I always harass James for new product news and was glad to jump on this one as soon as the pre-order hit the site. Thanks for hitting a wish list item for me! I will be painting mine as a C-37A... only wish I could find the tail number(s) stationed at Hickam 1998 - 2000. If not, I know 10065 or 60500 were there later.
  • BigJim
    Originally posted by Gilatrout View Post
    I've noticed a couple of potential issues in the videos. The first is that James seems to be carrying a ton of up trim on his elevators indicating that his CG and possibly the book CG is way too forward. The second issue is that in one of the slo-mo landings, it looks like there is some fuselage flex in the aft section.
    Both are easy to solve. For the flexing issue, I'm going to add additional carbon fiber slats internally along the tail and up the fuselage to stiffen the area where the two pieces meet. As to the CG, Ill figure out if I need to do more than move the battery after I add the stiffeners.
    March is soo far away....
    Saw the aft section flex during landing as well. I wonder how many landings the tail can take before they start to fail. I hope to remember this in March... age ya know!
    When I looked at the manual, I was curios about the 5mm of up elevator. After looking at many images, including those above, there is usually a pronounced negative angle of attack in the horizontal stab.
    This is such a sleek looking bird. It will be a welcome addition to the hangar.
  • mshagg
    Originally posted by James View Post
    Im going to wring it out more this week now that the reveal is done. I was babying it with it being the only one. Just needed enough footage for the hype video. Definitely will try to get Major Croasdale on the sticks. He was there for the flight I showed (had a new baby, hadn't seen him in a bit). Hang tight.
    But yes, Evan is right. The book calls for 5mm up, I did have to trim the elevator down on my maiden, but it was flying great for me so I didn't further play with it. I will now. Monday looks sunny and calm
    Lol I assume it's considered poor form for the head of global marketing to put the demo model in!​​
  • mshagg
  • Warbirdfan29
    I'm not usually into civilian aircraft, but I really like this model. Well done!
    For me this model came as a surprise, I would have expected a Hawker Hunter, a F9F Panther or maybe even a T-7A red hawk.
    In addition, there are countless variants of the "Gulfstream" that guarantee freedom for redesign and repainting.
    In Germany, for example, there is the HALO research aircraft.
    In other countries, the model is also used for military purposes. Think of the C-20 in the USA and the U-4 in Japan. Click image for larger version
ID:	332227Click image for larger version
Name:	85-3253-japan-air-self-defence-force-jasdf-gulfstream-aerospace-u-4-gulfstream-iv-g-iv-mpa_PlanespottersNet_959403_cf89f96289_o.jpg
ID:	332228Click image for larger version
ID:	332229Click image for larger version
  • GliderGuy
    Well said, Aros! But you neglected to mention that negativity is not an uncommon human trait. I am a member of 2 sailplane clubs…one large and one small. The larger one is rampant with politics and negativity. The smaller and newer one is rampant with positivity…so far (LOL was that a negative ending comment?).
    It’s good to be able discuss the inevitable design compromi$e$ and attempt to mindshare solutions. The MiG-29 is a prime example. Lord knows the negativity came hot and heavy with that bird. The end result, however, was several modifications were tried and flying techniques developed and MiG crashes were avoided. Mostly positive posts are now the norm for the MiG-29 (which….I hasten to add…is my favorite <albeit modified> EDF).
    Discussions about prop backplate cracking with the P-38 led to an improved backplate design (and thank goodness). Nose gear brace development for the large A-10 is another. How the top wing skin cracking issue with the AL37 can be forestalled with an internal bracing solution discussed in that forum is yet another…and so on and on for other birds discussed in their respective forums.
    Positivity is more fun. The PJ50 is, IMO, a positive…something fresh/different. Keep up the good work. But if a design compromise or odd flight characteristic is uncovered with the PJ50, I look forward to reading the work-arounds.
    I was pretty surprised by the initial negativity shown in the beginning chat from the live show. Then I realized that most of us resonate towards warbirds and military jets so we are pre-dispositioned to expecting that from Freewing. However, I have always been a huge proponent of diversity when it comes to varying classes offered in the hobby. And strengthening the civil class has always been top of my list. The AL37 was a tremendous genesis to kick off the class. This PJ50 looks to follow that same path. I am not concerned that this will be a model that doesn't sell well. In fact, I feel the opposite. I have a feeling it will be another one of our top sellers. What concerns me is this divisive attitude with some in the hobby. I recall reading someone's comments earlier today where he said something to the effect that "I have a hard enough time bringing my F4 to the club...If I bring this model they will laugh me out of the club!"
    Why?
    First of all, to me, that's not a very welcoming and inclusive club. We should embrace EVERY model that hits the market because it strengthens our hobby. An astute hobbyist said (paraphrase) "I love these new releases from Freewing! It forces the competition (FMS/E-flite, et al) to improve their models which in the end benefits us all!"
    And being an employee of Motion RC for 8 years now I can honestly tell you that is something we love too.
    I think there are a lot of people out there who don't realize that the bulk of Motion RC employees are all diehard RC pilots like most of you reading these words. Not faceless, could care less people. But people that want the same thing any RC pilot wants. Quality, attention to detail, diversity and above all else a product that delivers.
    It is of my personal opinion that some of the negative folks were plants from competitors. I won't name names. They will go to great lengths to undermine what we, and Freewing offer to the hobby and have for years now. No matter. Proof, as always, remains in the form of sales.
    I can't wait to snag this model. It hits all the right notes for me personally. And yes, there will be plenty of military jets and warbirds ahead.
