  • bill34207
    Originally posted by jay bennett
    well I have tested it on a new watt meter and it is pulling just over 100 amps on fresh packs and holds 94 amps, but it is not as fast as my stinger 90 and will not pull a loop without a run up so I guess I will have to get used to it or upgrade the power system when I get board of it, a bit disappointed as 80mm upgrades are hard to find. but you live and learn. waiting for the a10 now, many thanks for all the help
    Something is wrong somewhere. My Mig will out climb my old Stinger 90 from a low throttle level flight punch to full and pull elevator every time. They do offer a higher KV inrunner version but it's currently out of stock. https://www.motionrc.com/collections...20kv-in-runner
  • jay bennett
    anyone upgraded their mig 21 motor? is there a motor for the 80mm fan unit?
  • jay bennett
  • bill34207
    will change to low timing and see if that helps, I have set the power with the three beeps do I need to have trim centred or all up or down?
    Pat made a very good point that I forgot to mention. (just assumed that everyone knew it) Setting end point calibration is very important.
    I typically do mine with throttle trim in the middle. Power on the TX, move throttle to full. Plug in the flight battery and when it beeps twice pull the throttle back to the bottom. Operation completed.
  • jay bennett
  • gooniac33
    So I didn't fly my Mig this weekend but my buddies did while I flew other planes... I am bummed too because the coolest flight where my buddy was hovering his Mig and I was doing big barrel rolls around him....
  • gooniac33
    Jay,
    Did you calibrate your ESC initially? Radio on, throttle to max, plug in battery, wait for the two beeps, throttle off. This should set the throttle end points between the ESC and your radio. Maybe you're not seeing full throttle?
    That is a good point... didn't think of that..... yes that could do it as well
    Jay,
  • gooniac33
    timing set to high but no change, will the freewing inrunner give me more power? if so how much it seems very close to the out runner specs.
    timing set to high will just draw more amps. You will not get any extra performance that you will notice. Low timing is best for outrunner or inrunner. I use the inrunner set up on mine and it works great on low timing. My buddies use low timing on their outrunners with great results too
  • jay bennett
  • jay bennett
    thank you
    it seems that the esc comes with the timing in low setting will try changing to high
  • bill34207
    any links the the manual please
  • jay bennett
  • jay bennett
    packs are nano techs brand new for this model 45-90c, they get a little warm but nothing more, I have a esc from my stinger would it be worth swapping it for the one in the mig? I have a watt meter on order so this should help find the problem hopefully, the brake is not on. I have reset the esc with the throttle stick when the first two bleeps are heard but this has not changed anything.
  • Shirty
    Pic from the weekend. ::) agreed, check your esc settings as well jay. As an example, having brake on, will reduce your watts by at least 20%. The esc should be set up fine, I've never read of a freewing one needing changes but in other models it's got to me with brake set as on.
    Click image for larger version  Name:	IMG_1090.JPG Views:	2 Size:	313.4 KB ID:	73733
  • bill34207
    Something is definitely amiss Jay. The Mig is a rocket compared to the Stinger 90. Considering the % left in your packs after only two minutes I'd be suspect of them. You might want to hook up a watt meter and do some static testing. Sounds a lot like your pack(s) might be sagging under load.
    How old/new are they? It takes about 5 cycles to get a lipo broken in and working at full capacity.
    As for programmer, I don't know of one but the manual is available and it can be set with your radio.
  • jay bennett
    what programmer can I use to change the setting on the esc, I have two flights on mine and it seems under powered, will the inrunner that freewing sell make it any quicker?. I fly from grass and it takes forever to get to flying speed and when in the air it does not seem to get going and the new nano tech 5000 only get two mins and have 26% left is this correct? I have had a 90mm stinger from the same grass and it went like a rocket so I was expecting the same sort of performance.
    Originally posted by OV10
    Now don't tease us..........cause when I meet up with you at NEFI the first thing out of my yap will be show me that AB Dude LOL
    I definitely hope to be able to do that.
    You are warm Pat... I hope to debut a functional version at NEFI.
    Thanks Ryan.
    Thanks Ryan.
