Official Freewing 70mm F-22 Raptor EDF Jet Thread
i use safe select so i can turn it on and off, i just started in this hobby about 6 months ago so i use safe a lotComment
Just brought the 70mm F22 .On the esc red and black wire there is a small wire connected to the black and red esc wires with a small red 2 prong red connecter.Anyone know what this is forComment
Ok. Done a ton of searching. Can't find the answer. On the MRC website it shows a main gear pin in spare parts, but in the description it does not list the F22 as compatible. I need a new pin. Can anyone confirm the part number for main gear strut pin? I'd appreciate it!Comment
I suspect that since it is listed in the 70mm F-22 spare parts pages, that it's likely they omitted the F-22 reference. It's used in several different model retracts. If you go to RC Castle's webpage for the spare parts for this F-22, you will see the listing is for the F-22 pin and it looks identical to the picture in the MRC listing - same shape and same flats. If you have access to machining equipment, it's easy enough to make your own out of heavy duty wire stock or piano wire. Cut your own flats.Comment
