Official Freewing 70mm F-22 Raptor EDF Jet Thread
  • I agree but then he has shown FreeWing thinks it's great jet for a beginner.
    Originally posted by kallend View Post
    I don't think "SAFE" and "F-22" belong in the same thread.
    • duo bros rc on youtube also thinks it is a great beginner edf, but i would beg to differ
      • i use safe select so i can turn it on and off, i just started in this hobby about 6 months ago so i use safe a lot
        • My maiden
          • If the video will come through
            • https://photos.google.com/photo/AF1Q..._1-dkGRqYv0vOA i dont know if this will work
              • wrong plane
                • https://photos.google.com/photo/AF1Q...a6zZ_J54Bz4WgN this should be the right one
                  • The link isn't working for me.
                    • Ok
                      • Originally posted by brysoncolvin View Post
                        Ok
                        There is an "Edit" feature that allows you to correct your posts, you don't have to keep posting additional ones to correct accumulating errors.
                        • Ok, I couldn't figure it out on my laptop but I found it on my phone
                          • Morning flight with new KMRC afterburner. I'm setting the timer for 3 minutes from now on for the 3300 mAh batteries.
                            • Comment
                              • Weather was perfect: no wind, no mosquitoes and about 60 degrees. I wanted a very early pre-sunrise flight to get the full effect of the afterburner but forgot to attach strobe lights under wing.
                                • Just brought the 70mm F22 .On the esc red and black wire there is a small wire connected to the black and red esc wires with a small red 2 prong red connecter.Anyone know what this is for
                                  • Anything you need power for, most use it for an afterburner.
                                    • Ok. Done a ton of searching. Can't find the answer. On the MRC website it shows a main gear pin in spare parts, but in the description it does not list the F22 as compatible. I need a new pin. Can anyone confirm the part number for main gear strut pin? I'd appreciate it!
                                      • Originally posted by UXODAS View Post
                                        I suspect that since it is listed in the 70mm F-22 spare parts pages, that it's likely they omitted the F-22 reference. It's used in several different model retracts. If you go to RC Castle's webpage for the spare parts for this F-22, you will see the listing is for the F-22 pin and it looks identical to the picture in the MRC listing - same shape and same flats. If you have access to machining equipment, it's easy enough to make your own out of heavy duty wire stock or piano wire. Cut your own flats.
                                        • They use the same pin. Order it, and a spare.
