Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
  • RCAVI8T0R
    • Apr 2025
    • 9
    Motion released the STL files for the plane under the "support" tab. I just printed them myself.
      • 8791
      They look real good as if they were stock.
      • mr150m
        • Aug 2021
        • 3
        I would like to know the setup for Spektrum in order to get Flaperons and tailerons. I have the 110mm F-35C with the Freewing gyro that came with it.
        • RCAVI8T0R
          • Apr 2025
          • 9
          Airplane type: Wing: Flaperon - Tail: Taileron. Install a Y lead to join the flap and aileron on the wing coming from the bluebox in the plane. That worked for me. You will need a 10 channel receiver and completely bypass the stock gyro.
          • RCAVI8T0R
            • Apr 2025
            • 9
            I printed them with ASA so they are lite, and the sun doesn't affect them. Makes a nice addition to a very nice plane. Still iffy on flying with them on though.
            • flyjets01@gmail.com
              Flt Test
              • Apr 2026
              • 29
              • Western NC
              Just started testing various items on the F35 110mm. Seems my Freewing EG01 6 Axis Gyro needed to be reversed on Elevator.
              I also tested Amp draw this is per battery 100.1 Amps when charged at 4.20 if LHIV charged at 4.35 she pulled per battery 106.1 Amps.
              When setting up the RadioMaster TX16s I needed to increase the Aileron and Elevators to 150 weight to get the Spec control throws.
              I'm also calculating the Thrust at 1.1 very similar to my 8S 90mm F22.
              Management is doing things right; leadership is doing the right things.
              • Shaun Evans
                • Apr 2021
                • 123
                • California, USA
                Anyone? Wheel diameters please?
