Motion released the STL files for the plane under the "support" tab. I just printed them myself.
Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
Airplane type: Wing: Flaperon - Tail: Taileron. Install a Y lead to join the flap and aileron on the wing coming from the bluebox in the plane. That worked for me. You will need a 10 channel receiver and completely bypass the stock gyro.
😀 1Comment
Just started testing various items on the F35 110mm. Seems my Freewing EG01 6 Axis Gyro needed to be reversed on Elevator.
I also tested Amp draw this is per battery 100.1 Amps when charged at 4.20 if LHIV charged at 4.35 she pulled per battery 106.1 Amps.
When setting up the RadioMaster TX16s I needed to increase the Aileron and Elevators to 150 weight to get the Spec control throws.
I'm also calculating the Thrust at 1.1 very similar to my 8S 90mm F22.
Management is doing things right; leadership is doing the right things.Comment
Maidened today and managed to get 7 total flights. I flew 25-30mm aft of the marks. What a great flying plane, power for days, good behaviors all around.
I setup tailerons and AS3X+. Most surprising was how much momentum it carried on the ground. Also, the inflight sound is incredible.Comment
Mine is not delivered yet but you say those lights are on a switch, right? Why don't you just leave that switch in the ON position? When the battery is plugged in, the lights are ON.Comment
Ciao, hai usato la miscelazione degli alettoni? Coda a V?Maidened today and managed to get 7 total flights. I flew 25-30mm aft of the marks. What a great flying plane, power for days, good behaviors all around.
Maiden flight day for both of our 110mm F-35s is complete. What a great jet. Check out our tandem flight. I hope that this time MotionRC will show our jets on their next livestream.🤞🏾
Best jet on my hangar so far. Thank you Freewing and MotionRC for this jet. You all have a great rest of your day. Greetings from Douglas, Arizona, USA 🌵🌵🌵😁👍🏾🇵🇷👍 1Comment
My AfterBurner light comes on at like 20-30% throttle. is there any way to adjust that to like 75%?Comment
Nevermind, I got the wheel diameters when I opened the box and measured them. Was just looking for a tiny bit of help....👍 1Comment
Friends!
I assembled F-35 today. But it was a disappointment to fail to set up the ESC / Throttle control. I use Spektrum receiver AR10100T with satelite and Spektrum Transmitter.
So when I bind everything works, except the throttle. Plus it keeps emmiting beep tones as you power on.
I tried everything: all the possible combination of throttle stick, throttle cut and reverse. I replaced with another receiver, add a new model from scratch . Nothing works so far.
Do you have any ideas what could possible go wrong? The pity side is .. I can't find a manual for this ESC.
CheersComment
Ciao una cosa magari già provata sembrerebbe tu lo abbia in programmazione. Magari invertendo da radio l acceleratore? Chissà, ma attenzioneFriends!
Cheers
