Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
  • RCAVI8T0R
    • Apr 2025
    • 10
    Motion released the STL files for the plane under the "support" tab. I just printed them myself.
      • 8799
      They look real good as if they were stock.
      • mr150m
        • Aug 2021
        • 3
        I would like to know the setup for Spektrum in order to get Flaperons and tailerons. I have the 110mm F-35C with the Freewing gyro that came with it.
        • RCAVI8T0R
          • Apr 2025
          • 10
          Airplane type: Wing: Flaperon - Tail: Taileron. Install a Y lead to join the flap and aileron on the wing coming from the bluebox in the plane. That worked for me. You will need a 10 channel receiver and completely bypass the stock gyro.
          • RCAVI8T0R
            • Apr 2025
            • 10
            I printed them with ASA so they are lite, and the sun doesn't affect them. Makes a nice addition to a very nice plane. Still iffy on flying with them on though.
            • flyjets01@gmail.com
              Flt Test
              • Apr 2026
              • 29
              • Western NC
              Just started testing various items on the F35 110mm. Seems my Freewing EG01 6 Axis Gyro needed to be reversed on Elevator.
              I also tested Amp draw this is per battery 100.1 Amps when charged at 4.20 if LHIV charged at 4.35 she pulled per battery 106.1 Amps.
              When setting up the RadioMaster TX16s I needed to increase the Aileron and Elevators to 150 weight to get the Spec control throws.
              I'm also calculating the Thrust at 1.1 very similar to my 8S 90mm F22.
              Management is doing things right; leadership is doing the right things.​
              • Shaun Evans
                • Apr 2021
                • 123
                • California, USA
                Anyone? Wheel diameters please?
                • RCAVI8T0R
                  • Apr 2025
                  • 10
                  I am curious on if anyone is flying on the Admiral 6000 pro packs. If so, are you stacking them, or strapping them side by side?
                  • Bushong
                    • Sep 2026
                    • 2
                    Formation Light Controller
                    Does anyone know if there is a way to have the formation lights unswitched....so they are on any time the batteries are plugged in. I don't see any way to do it, just thought I would ask.
                    • Wrex450
                      • Dec 2025
                      • 2
                      • Austin, TX
                      Maidened today and managed to get 7 total flights. I flew 25-30mm aft of the marks. What a great flying plane, power for days, good behaviors all around.
                      I setup tailerons and AS3X+. Most surprising was how much momentum it carried on the ground. Also, the inflight sound is incredible.
                        • 8799
                        Mine is not delivered yet but you say those lights are on a switch, right? Why don't you just leave that switch in the ON position? When the battery is plugged in, the lights are ON.
                        • Giovanbattista
                          • Sep 2026
                          • 5
                          Hi, did you use aileron mixing? V-tail?
                          • Giovanbattista
                            • Sep 2026
                            • 5
                            Ciao, hai usato la miscelazione degli alettoni? Coda a V?
                              Elbee commented
                              Editing a comment
                          • Bushong
                            • Sep 2026
                            • 2
                            I'm trying to get out of using a channel just for the lights.
                            • Ricardopr54
                              • 9
                              Maiden flight day for both of our 110mm F-35s is complete. What a great jet. Check out our tandem flight. I hope that this time MotionRC will show our jets on their next livestream.🀞🏾
                              Best jet on my hangar so far. Thank you Freewing and MotionRC for this jet. You all have a great rest of your day. Greetings from Douglas, Arizona, USA πŸŒ΅πŸŒ΅πŸŒ΅πŸ˜πŸ‘πŸΎπŸ‡΅πŸ‡·
