Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
    • 8830
    Originally posted by flyjets01@gmail.com
    Evan what's your Cell % after 7.5 min?
    Here is my Maiden.
    Watch this on YouTube and select HD. As seen embedded here, the quality is at 240p, very fuzzy. HD is MUCH better.
      • 5415
      I don't remember but around 59-60% and just at 3.9V. I'll probably add another 30 seconds for my next flights.
      She really floats, doesn't she? This is the only plane I have to use full flaps landing to get it slowed down.
      • flyjets01@gmail.com
        Flt Test
        • Apr 2026
        • 32
        • Western NC
        Evan I think it's the weight that keeps it's moment up. Reminds me of my larger Turbine models.
        Ian
        Management is doing things right; leadership is doing the right things.​
        • Giovanbattista
          • Sep 2026
          • 26
          Hi Evan, so did you use the Flapperon setting? If you landed with the flaps down and then retracted them to use a single aileron… thanks
            • 5415
            Giovan, I'm not sure if flapperon is the correct term. I think that would be your ailerons also acting as flaps (or full span flaps). I pulled the flaps from the MCBe and mixed full span ailerons. So when on the flaps act as ailerons so it is full span ailerons. I am using them every flight. I have the mix on mu retract switch so when the gear are down they are not active and I have standard ailerons and standard flaps. When the gear are up then the flaps are mixed with ailerons for full span ailerons.
            • Giovanbattista
              • Sep 2026
              • 26
              Oh, okay, Evan. I get the model now—you’ve just been experimenting with different mixes. If it gives you such amazing results, I’ll give your great idea a try.
                • 5415
                I wanted more roll rate but didn’t want to do tailerons since I am using the stock gyro.
                • EDF-Jetpilot
                  Jets are a lot of fun
                  • May 2024
                  • 137
                  • Aarburg, Schweiz
                  I’m going to set up tailerons, and—much like on the F-14—I’ll mix the ailerons with the flaps; this is true to the full-scale aircraft and I’m convinced it will yield the best flight characteristics. ;-) I’ll also be using the AS3X+ stabilization system, since I fly with Spektrum gear. It’s really interesting to read about the different flying styles here on the forum!
                    • 2716
                    Here is my Maiden.
                    Nice maiden and excellent landing. What a beautiful place to fly, where are you?
                    She's obviously grass take off capable.
                      Flt Test
                      • Apr 2026
                      • 32
                      • Western NC
                      Brasstown Flyers Details
                      • Address: 811 Settawig Rd, Brasstown, NC 28902
                      • Coordinates: 35.04765, -83.9478
                      It's a small club in the very western tip of NC.
                      Ian
