Official Freewing 70mm F-16C Falcon V2 Thread
    Ace Hardware standard stuff.... Good paint really, I have painted over the white with the red and blue, and other combos... No wrinkling, runs, creeps, etc. So then the clear should have been compatible, right??
      Hey, but the canopy is moving along. Just have the little gray fuselage corners to do!!! :Cool::) (also, the 1600mm Spitfire is calling me.....:Sweating:)
      • Boots Whirlygig
        • 560
        • Granville Ohio USA
        You sure would’ve thought. Hey Rustoleum, what gives!?! Maybe too wet of a clear coat? Just don’t know. Shouldn’t have happened in my mind.
          Yeah maybe the clear was bad from the factory?
          • urrl
            • Oct 2013
            • 494
            Friday morning flight
            • Prowler901
              • 940
              • Gunnison, CO
              Beautiful flying urrl! And, beautiful place to fly. I hope to maiden mine very soon.
              • urrl
                • Oct 2013
                • 494
                Thanks Prowler.
                My morning flight
                • JohnVH
                  • Nov 2017
                  • 259
                  • Lynden, WA
                  Great flight, with a bad landing
                    • 8207
                    You need to rethink your definition of bad landing mister. That wasn't a bad landing. I could show you a bad landing! LOL LOL
                    • JohnVH
                      • Nov 2017
                      • 259
                      • Lynden, WA
                      Haha! Maybe so!
                        • 7334
                        LOLLOLLOL Yeah, I could say something, but I will pass!!
                          All you had to do it just taaaap the brakes alittle lol the landing was spot on, you just have to work on the taxiing after words.
                          • JohnVH
                            • Nov 2017
                            • 259
                            • Lynden, WA
                            Im going to add brakes, anyone know what diameter the axles are?
                            • Ron1950
                              Retired ATC
                              • Oct 2015
                              • 887
                              • brandon ms
                              hey Urrl where ya all get a lake? lol as I recall there are lakes in markem park but not at the flying field :)
                              • gooniac33
                                The Original Gooniac
                                • Jun 2016
                                • 1047
                                You are being way too hard on yourself!! Landing was good! Just gotta get used to the way it lands so that the speed will be a lil lower. this plane does not like to turn on the ground with any kind of speed...
                                • gooniac33
                                  • Jun 2016
                                  • 1047
                                  my flights from last weekend...and the week before.
                                  • kenelder
                                    Never enough planes!
                                    • 28
                                    • Largo, Fl
                                    There was no wind at our field today. I obtained some interesting info: my GPS is telling me that a high alpha pass (30 to 40 deg angle of attack) using thrust to hold altitude is at 20 mph (sometimes 19 or 18)!!! It sure looks slow and majestic. Yet plenty of power to accelerate vertical from a slow pass like that.
                                    Completely stable with full UP elevator, pretty amazing. I’ve mixed additional UP on a switch for assisting in landing, touches down on the mains and tail cone. Awesome plane! Still rolls a long way, got to tighten up the axles a little bit.....
                                    • gooniac33
                                      • Jun 2016
                                      • 1047
                                      Nothing cooler than a super slow high alpha pass just inches off the deck and seeing the dust blow away as you travel down the runway. It is one of my fave things to do!!! Mine is a lil heavier so I was able to get a 23mph High Alpha pass with no wind. With wind the passes were at barely 13mph ground speed....
                                      • Ted7rns
                                        CVF Warbird Squadron CO
                                        • Mar 2015
                                        • 26
                                        • Newbury Park, Cailfornia
                                        Okay I have read through all 34 pages, and I think I'm more confused then ever... lol.
                                        I have Roaring Top 5000mAh 45c batteries 755g..... will they work? Or is it too nose heavy?
                                        thanks for the help.
                                          • 8756
                                          I fly mine with a 4000mah Admiral weighing in at 600g. When I used a 5000mah, it wouldn't get off the ground. I fly off rough grass and it would not rotate in the distance available to me.
