Official Freewing 70mm F-16C Falcon V2 Thread
  • Originally posted by runway14left View Post
    Thanks for the input. I thought that would be the case. I bought the 6 cell version and am trying to "ease" into all the power it will have. Time to buck up I guess!
    The 6s version isn't crazy powerful... It flies well and is VERY easy to manage.
    Easier than the 4s version which requires much more throttle to fly. Plus, the heavier weight of the 6s setup also makes it track better and with more resilience to wind buffering etc.
    6s is the way to go for 95% of fliers.
    Again, this plane is not "Fast"... It just flies well and has a nicely balanced power system out of the box.
    • I agree. F-16 fly's " just okay" Thought she would be faster than she is but my Yak-130 with the same xrp 2200kv 14b combo &125 amp esc will pass her like she's standing still. Was surprised as the Yak has such a fat belly and the F-16 , a more sleek airframe. Might have something to do with the air intake on the F-16/ Very constricted IMO.
      • Originally posted by dahawk View Post
        Absolutely... thrust gram for gram... The Yak performs MUCH better.
        I actually scaled back my F-16 setup for a moderate one to get more flight time because the extra power didn't really net much over stock.
        Granted, it was faster, but NOTHING like the gains I saw from stepping up my Yak.
        • So I have my new F-16 assembled, painted and pretty much ready to go. Just a couple finishing touches. Hoping to maiden it Sunday.
          I don't think it shows up in the picture, but the pilot's name is actually a friend of mine that just retired from Lockheed Martin.
          • That's a beautiful job! :Cool: I'd like to get one of these someday.
            • Excellent work! Very sharp, well done!
              • Quick question, is it just me or does this plane loose lots of altitude while in a bank turning ? I'm c/ged correctly and the glide slope is incredible , just can't make a turn without losing LOTS of altitude. Anyone else having this problem ?
                • Originally posted by Felixs10 View Post
                  You need to use opposite rudder to keep altitude... 101 flying bud.
                  Bank and yank doesn't cut it.
                  • Originally posted by Alpha10 View Post
                    Thanks Alpha , I get it .. I have been flying for many years and I do use opposite rudder in turns , I guess I wasn't clear in my original post on just how much effort the V2 -F16 needs to make coordinated turns. I wouldn't expect it so much from this model , the star fighter yes , this one no . I was wondering if I missed something .
                      You are possibly flying nose heavy. You want the nose to drop a little bit but not just plunge down to the ground at anything beyond 45 degrees. I use a huge 6s 35c 5800mah pack and the plane doesn't dive like crazy when banked.
                        Opposite rudder? Can you explain the why behind that?
                        • Originally posted by gooniac33 View Post
                          Thanks Gooniac ! I'm going to try going moving the battery back . I do have a severely noticeable drop that needs tons of opposite rudder to correct. I was wondering if I should play with the C/G . I will move the battery back in 1/4 increments and see what happens .
                            My batteries are almost all the way back. Just the very front is being held by the strap. And that goes for any pack that I use in the plane. 4000, 4500, 5000 or 5800. All in the same place.
                              Thanks Again .. My 4500's are about mid- 3/4 of the way back . But to be fair I have brakes on this one which brings the C/G back anyway . We fly off a 250' runway and without brakes it needs just about all of it to stop .. I will move the LIPO back this Sat..
                                Yeah, it could use a little more aft CG I'd bet... However, the F-16 has always had a pretty wicked turn in without quite a bit of opposite rudder in the turns (The most aggressive I've seen IME)
                                A nose heavy CG would definitely make it worse along with a higher wing loading.
                                But keeping this plane as light as possible definitely makes a big difference in it's flight character.
                                I went back down to 3700mAh and it's much better than my 5000 setup IMHO.
                                After tying multiple setups... I'd honestly recommend staying with the stock 2300 setup with a good 3300 mAh pack. Can't beat it for the money!
                                  How far back are you putting your 3300's ?
                                    Not far at all... My 510g TP 3300s we just flush with the back of the canopy edge, but I had a slightly lighter power system in mine so that could vary a bit.
                                    • Check out my flights from this last weekend. I was putting on shows with it every flight!!
                                      • Have had this 6S version with upgrade gear since last Feb. Had not done the maiden. I fly from a grass field and with all the rain we've had, the grass was still quite thick. I've been flying the pants off the FW 80mm Avanti S and 80mm FW A-10. So I decided today was the day. Took a few Admiral Pro 4000 packs out, did all he checks and put her on the runway. The grass was cut yesterday and was stiil just taller than the nose wheel.
                                        Full throttle and she tracked straight. After about 50 yards, she finally cleared the turf. Gear up and two clicks of up and she was cruising. A boat load of fun with no bad habbits. After 3:00, dropped the gear and set-up for landing. Set throttle to about 10% with around 10 deg nose high and she settled in nicely on the mains. My biggest concern was that the small wheels and gear would not handle the thick turf. It was a non-issue. The upgrade gear did exactly what it was supposed to do. I'm pretty certain that the stock gear would have really stressed things as the field is a bit bumpy too. Very happy!
                                        Loaded in a fresh battery and decided to try the bit of flapperon out that I'd programmed in earlier. Lined up and went full throttle. She was off in half the distance. A great flying little jet. Scoots along nicely and looks great in the air. No need for flaperons on landings. Just keep the nose up and let her settle.
                                        All four of my current EDF's are Freewing. The 64mm HP Stinger(12 blade), the FW 70MM F-16 V2, the FW 80mm Avanti S, and the FW 80mm A-10. There's not a bad one in the bunch. I've seen many other brands try to fly at our field and all were unimpressive and not up to the task. In recent months more Freewings are showing up and so are the smiles to go with it. Great job Freewing and MRC!
                                        • Uggh almost pulled the trigger on this one but noticed the non -full flying stabs... come on Freewing, why go cheap on us... same reason I passed on the Fishbed..too bad seems to fly great. And they added full stabs on the new 64mm F-18's ... they confuse me...
