    Nice, mine struggles to get 105 lol. I'll have to keep pushing it.
  • ochoaoctavio89@icloud.com
    I need to get a better run with my 90mm. I know it has more speed in it, I just haven't got a decent pass with it yet.
    I actually put a GPS speed tracker on mine on a dive and 8 mph wind I did 130 mph stock out of the box with the 1900kv inrunner
  • Gravythe clown
    Check and make sure it’s not plugged into the UBEC port instead of the tail flame port.
    Gravy
    Originally posted by millerjr88
    Does anyone know how to get the afterburner LED light to only come on at half throttle and above? Mine lights up as soon as battery is plugged in, which is just not scale. I contacted Motion and they were no help, just told me I had a bad circuit board and sent me a replacement that works just like the original. The online video shows and describes it only coming on at half throttle and above. I am using a Spektrum DX9 with an Admiral 6 gyro receiver. Everything works as it should except the stupid afterburner being on with throttle off. Not sure how you would do a throttle mix to fix this as the lights are controlled by the circuit board, not a receiver port. Any help is appreciated.
    On mine it comes on at 1/2 throttle, so not sure what's up with yours. I suspect, as DCORSAIR mentioned, it is plugged into the wrong port, most likely one for solid lights (no blinking) which would most likely be the wing tip lights. See if you can find another light port. If you look in the manual on page 10, it shows the correct port for what they call the "Flame Light" on the circuit board, which is at the bottom of the board just past the Throttle connection and the UBEC connection. If it's plugged in correctly, then you've got a real mystery on your hands.
  • DCORSAIR
    I've had 5 of the F-16's and never ran into that issue, wonder if the afterburner light is plugged into the wrong port on the circuit board or is that possible? I sold all my F-16's and don't have one in front of me, it was just a thought.
  • millerjr88
  • Peter Flinn
    Thank you so much mate for the help and guidance with set up. I will follow and tweak slightly to the things you have done and I think it should be sweet! I don't think I will have the urge to upgrade to a 8s setup purely because it costs a lot more and we don't really see a huge difference in speed. I got other planes for that purpose that are pushing 300km/hr which is plenty for me:) I see the f16 as a scale flying jet that I just want to enjoy flying it around watch those beautiful gears in action. So cool. I purchased the in runner 9 blade version and will keep posted on how it goes....😉
    Originally posted by Peter Flinn
    Also mate, did you find the need to change your elevator servos? What about the power system; do you feel like it has enough power? Also anything I should be aware of with the plane. I have also been curious of where to have the elevator set at. Any reference for its location will be much appreciated.
    I did not change my servos (probably just lazy) and have yet to have a problem after about 120 flights. I did, however, put a carbon tube around the elevator control rods to stiffen them up, not that there was a problem, just to be safe.
    I'm using the 12 blade 1835 Kv inrunner along with a Castle "Cremations" Phoenix 130 Amp ESC with an integrated 5A BEC. I purchased the ARF at a time the F-16 only came with the 1750 Kv outrunner (which was not going to cut it for me) so put the 12 blade inrunner in and an ESC of my choosing. Now that it has been upgraded with the 9 blade 1900Kv inrunner, I probably would have just bought the stock F-16 or at least left the FW 130 amp ESC in it. Not sure what the difference in take-off or vertical is between the 12 blade and the 9 blade, but I believe the 12 blade has more punch, but may be slightly less on top end.
    I definitely feel I have enough power, however, if you want to go to the wall, set it up with an 8S system. I don't have the right set of batteries for an 8S setup and with over a 100 batteries already, not too keen on adding to that inventory. I just helped one of my flying buddies put together the FW Thunderbird F-16 with an 8S system and the FMS fan. Flew it last weekend with me and although it seemed like it had a higher top end speed, I didn't notice that much difference in our respective take-off distances (he also set up flaperons, but left the stock 1 3/4" nose wheel and I changed to a 2" nose wheel). He also didn't achieve the 5 minutes of flight time I'm getting using the SMC 8100, but he got over 4 minutes. The battery compartment is large enough to handle just about anything and the airframe does not seem to be bothered with extra weight.
    Nothing in particular that you need to watch out for, except maybe that if you balance it further aft than around 140 mm, it flies high alpha exceptionally easy, but on landing at a speed just before it will wing stall (which is about the right landing speed) it will automatically go into high alpha with no up elevator, rise up a few feet, stall and come down HARD! That's always Exciting! I fly mine at the aft end of the recommended CG at 128 mm gear down (which is 130mm gear up). I now fly it fully loaded with ordinance because it looks just so bad .ss and doesn't mind the added weight or resistance. You may also find the recommended throw on ailerons to be on the aggressive side, so definitely program in some lower rates as well for the maiden and then push it to where you feel comfortable later. I'm only using 18 mm of flaperons for take-off and 23 mm for landing. My neutral elevator position, balanced at 128 mm and using the 905 gr SMC 8100 is below. The Thunderbird F-16 used the same setup and required very little trim on the maiden. The included ring afterburner is OK at dusk, but fairly anemic in the daytime, so I also installed an RC Geek burner to compliment it. An F-16 just has to have a decent After Burner! You should enjoy this one, Happy Hunting!
  • Peter Flinn
    Mine gets off grass cut to about 3/4", in 120 feet which is just under 1/2 your 70 meter runway. I'm using a heavy SMC 8100 mah battery though and have the 12 blade inrunner which has a bit more horsepower for take off. I have also put a larger 2" nose wheel on it and set up flaperons. I would definitely recommend you set up flaperons if you need to get off grass. With a lot of dew on the grass you may not be able to get off if it is too wet. The F16 has a rack of cheater holes just in front of the fan that can suck up a lot of grass cuttings and water. It's a spectacular flying EDF, easily gets into high alpha and is a blast to fly so you should love it. You definitely also need a true higher C battery for the inrunner to get the most out of it. The attached flight may help you judge the take off distance.
  • Peter Flinn
    Mine gets off grass cut to about 3/4", in 120 feet which is just under 1/2 your 70 meter runway. I'm using a heavy SMC 8100 mah battery though and have the 12 blade inrunner which has a bit more horsepower for take off. I have also put a larger 2" nose wheel on it and set up flaperons. I would definitely recommend you set up flaperons if you need to get off grass. With a lot of dew on the grass you may not be able to get off if it is too wet. The F16 has a rack of cheated holes just in front of the fan that can suck up a lot of grass cuttings and water. It's a spectacular flying EDF, easily gets into high alpha and is a blast to fly so you should love it. You definitely also need a true higher C battery for the inrunner to get the most out of it. The attached flight may help you judge the take off distance.
    Thanks for the advice and help. I will pull the trigger and get one:)
    Hahaha, yes I do. I love flying the freewing mirage 2000 and have a little trouble rotating however until I hit that launch ramp that my field has. However, I only got the mirage this winter here in Australia so the dew of the ground makes it very wet. I generally run the tanks and 3d print a centre tank that kinda rubs on the grass slightly but manage to still rotate. I still should be good with the Falcon I hope...
  • Peter Flinn
    I think it could be done. Do you have any other edf planes? Do they have any trouble lifting off? Minus the F22, that one can get off the ground if a mosquito farts.
  • Peter Flinn
    G'day guys. Was thinking about purchasing the in runner version and thought whether my field will be long enough. I would say it is 70 metres with short grass. It has a slight "launch ramp" at the end of the field that is roughly at an angle of elevation of 4 degrees. Do you think the F16 will be suitable at this field...?
    Heck yeah, straight into vertical
  • DCORSAIR
    Well finally flew it again today. I really love how this plane flys. One of the coolest looking planes on takeoff rotation
    Nothing like rotating the F-16 and pulling the gear up at the same time.
    Lmao yeah, I used the glue that came with the plane, so I can still be removed without much damage
  • DCORSAIR
    What I found to be the problem on most of my EDF jets, the magnets were installed backwards, my one A-4 was really bad, it had two installed backwards on the avionics hump, lucky I caught it before I lost it in flight, I've had 5 of the F-16's and even though they seem loose, I never lost one, looks like you took care of the problem anyway...
    Yeah I had already glued it on. It's all good though
