  • SDRick
    Has anyone who received the new performance model that became available last week have any feedback or videos?
    Nice! I love mine on the 6S inrunner setup. Not blazing speeds but MUCH better than stock.
  • vduniec
ID:	269571 Bought a used Viper from a friend. Excellent condition. First step of the repaint is to get the wells, doors and struts gloss white.
    Before repaint started, I maidened it on a 6S in-runner setup just to make sure the trims and balance were all set. The plan was to put it on an 8S setup like my other 90mm F-16.
    I have to say, I might keep it on the current setup. Obviously, it’s not as fast as the 8S and the vertical isn’t as impressive but it flys and lands so much lighter I just might keep it as is.
    gooniac33 thanks for your input, really appreciate it. Can't wait to here how you like the 8S set-up on this bird. I do like the 12 blade 1835Kv set up in mine, but had it since day 1 so can't compare it to anything else. I'm not that interested in speed, have more the need for thrust to get off the grass and this fan seems to do just fine, and I too am seldom at full throttle.
  • gooniac33
    Nice!! Is that the same EDF that now comes in the BA F-18? I think so, should make a nice upgrade. Although the more I fly mine with the 12 blade 4068-1835 Kv inrunner, the more I like it. Flew my Wisconsin Fighter wing version today and even in 98 degree, humid weather in dead calm wind, it got off the grass in 100 feet. Any of you EDF "masters" out there that can tell me the performance difference in the 12 blade 4068-1835 inrunner versus the 9 blade 3672-1900 Kv inrunner?
    The biggest advantage to the new 9 blade is the weight and power consumption at full throttle! I have seen my buddy Nate fly his new F-18 for almost 6 mins (not lazy flying.....HARD) And the battery still had 3.75v per cell and the battery was barely warm. This was a 5000 pack as well!! With the 6000s he was over 3.8v per cell!! In other words the batteries were very happy!! The new fan is a great option and much better all around performance than the older 1835kv set up. 9 blades are the perfect number for speed and endurance it seems. Personally I prefer the higher blade count fans for their part throttle advantages since that is the way that I usually fly. I am willing to take a slight hit full throttle amp draw because I spend so little time there anyway. I wonder how good it will do in the F-16?
    However I am setting mine up with an 8s set up... stay tuned... hopefully will get it in the air this weekend!!
  • Johnnyrabuse
    do you think the 8 cell 1380 I currently fly in this jet can handle tens? I use a 150 hobby wing esc no one seems to know I’m liking mine on eights tailerons only flaps only on wings no flaperons for me it lands great I know it can handle the weight
  • Mizer67
    Originally posted by Aros
    Yep that's the one! I too like my 1835kV inrunner in this jet. Wonder what difference the 1900kV would be?
    If RC Castle's specs. are accurate you get 100 more grams of thrust with a weight savings of 72 grams and higher efficiency of between 5 and 15 amps.
    If course, getting accurate specs. is somewhat challenging, but the 1900kv motor sounds very good from the looks of it vs. the 1835 kv one. Probably not worth changing if you have it already, but good if you're buying new. Plus it's significantly less expensive.
    All that being said, I'd speculate the larger 39-40mm inrunner motor still does better with acceleration.
    Look what's coming soon kiddies!
    https://www.motionrc.com/collections...mm-edf-jet-pnp
  • gooniac33
    Ok I have one coming finally! Got a Thunderbird and will be doing something special with this one! Should be fun!
    DCORSAIR thanks for the complement of the landing, but it just goes to prove that even a blind squirrel can occasionally find a nut.
  • DCORSAIR
    Got the F-16 out yesterday to try the nose wheel modification and a couple different batteries from the RT 5500 70 C I've been using. This time changed the livery to the Fighting Razorbacks version and got it out with a stiff 15-20 mph wind. I tried the HRB 6000 mAh 50C and the Hobbystar 8000 mAh battery Phantom had suggested to me (thanks for tip).
    First off, the new nose wheel worked like a charm, it took off with each battery in less that 100 feet (before that it took a good 130-150 feet), so the slightly higher AoA on the runway helped and the larger wheel (going to 2" from 1 3/4") resulted in much less drag on the grass runway, allowing it to reach V1 much easier. And it was a hot, humid day, which makes it perform like it's at a higher altitude than being at sea level. As far as the batteries, the HRB performed great, virtually the same thrust as from the RT and at the same weight (but at least $40 bucks cheaper in cost), but gave about 20 seconds more flight time (an eternity in EDF's). Surprisingly, the HS 8000 (at 900g) performed just as well and gave an additional minute over the RT (but still need to fly that battery more to gauge it's ultimate performance and flight time). So now the RT 5500 is out and the HRB and HobbyStar are in. It seems the upgraded 12 blade 4068-1835 Kv inrunner in this is worth it's cost, cause if it can fly well with a brick like the HS 8000 in it (after already being considered a "heavy" jet), that's saying something.
    Unfortunately, I noticed that Hangar 9 no longer makes the 2" Pro-Light that I used but was lucky that I had several from other planes I no longer have. Not sure what a good alternative to that would be because the diameter was perfect, with only slight modification to the strut, and the width was just right and the axle hole could be drilled out to the right size. And it's not as "mushy" as the stock wheel so rolls on grass easier.
    Also modified the SU-30 nose wheel to the 2 1/4" Hangar 9 (which are still made) and that also worked wonders for that flying bus (at least on take-off, it still flies like a tank). But the HS 8000 was just too heavy for it, although it took off in the same distance, but it flew like :poop: needing almost full throttle to keep it up (and thereby losing any gain in flight time) and ending up with very strained vertical. No HS 8000 for that beast anymore!
    Anyway, I have attached a really bad video of both take-offs with the F-16 here, but don't give me any heat over the poor quality of the video. It was take with a friends cell phone, the wind was making it shake and I think we both had a few too many shots earlier, but at least it sort of proves that the modifications worked and the batteries are usable. Here's the video:
    Click image for larger version  Name:	20200731_141329.jpg Views:	0 Size:	225.4 KB ID:	266186
    Wow Hugh, great to see another pilot figure out how to land the F-16, it's a great jet to fly once you get the landings down, nice stable descent with a slight nose up and a flare at the end, sweet.
    Ever since our club's lawn equipment went DOA and they got a new machine, which doesn't cut as low, I've been struggling to get a couple jets off the runway, the SU-30 and the F-16 (even with flaperons and the upgraded 12 blade inrunner in the F-16). A couple days ago I was able to get a 2 1/4" Hangar 9 Pro-Lite wheel on the SU-30 which required almost no modifications, so today I struggled to address the F-16. Both had a smaller 1 7/8" wheel in the nose. Well, after several hours of grinding and modifying (and a bunch of choice words :face_with_symbols_o), I was finally able to get a 2" Hangar 9 Pro-Lite on the F-16 nose. I had a few of these from other planes I don't use, but noticed they no longer sell them, the smallest being available now is the 2 1/4".
    I did need to grind down the wheel assembly without destroying the functionality of the shocks so it would turn freely, and then I had to do a slight modification to the gear door. Cut the opening of the hatch aft so the wheel would swing in and had to put a small hole in the aft portion of the door over the high point of the wheel so it would close completely, but otherwise not that bad. Don't know if this will help, but I'm darn sure it won't be any worse.
ID:	264831Click image for larger version
ID:	264832Click image for larger version
  • Rcfiddy1
    What is a good replacement servo for tailerons?
  • Phantom
    Phantom just posted the results of my battery IR testing and power testing on the 4068-1835 Kv inrunner in the F-16 (along with other EDF's) under 2 posts in the Batteries catagory titled LiPo Wars: Admiral vs RT/HRB/HS. I included tests on the Hobbystar 8000 you recommended (thanks for the tip) and was a little surprised how well it did given the size and weight (is it 100C, not a chance but then what is). I'm going to use it in both the F-16 and SU-30 (fits in that even easier) for longer flight times. I was using the RT 5500 70C, but the HS 8000 is just as good (along with the HRB 6000) as the RT but both have more capacity. So the RT is now on extended vacation. :sleeping:
    Hugh,
    I really appreciate your IR, and C rating testing. I've often wondered how far off the manufacturers were from their claims...
  • Phantom
    The 16 is just a helluva lot heavier, with higher wing loading. In contrast the 15 is lighter, with lower wing loading, simple physics.
  • Johnnyrabuse
    Originally posted by Phantom
    So do I, my experience is completely opposite.
    I bet that it's a cg issue I have both jets the f15 retracts are glass compared to the f16s
    The both 90s fly ok on sixes but they really needs 8s at the least and tens to really shine and fly true scale
    My F 16 fly's on rails eights lands like a *****cat on tailerons flaps mix
    Spoilerons create instability for me I avoid them
    As far as the f 15 goes on six's I really have to fly it all the way in .... For me on final the F 15 tends to want to tip just as I settle in ....
    Battery bays way better in the 16
    If I cut the floor I can easily fit two 6000 admiral four cells
    The f15 is a wiring nightmare if you want to fly tIl heavy
