Ok boys well as you know.... I finally got the F-16!! But I didn't do what anyone else has done yet... Yes it is 8s but it is not one that anyone has used yet. I am using the new FMS 1500kv 12 blade set up and OMG is it a beast!! It took a few flights for the motor to loosen up a bit but now that it has.... WOW!! The plane is insane and can climb straight up as soon as the wheels are off the ground! Here are a couple videos... more to come as well..
here is it's second flight! Already doing formation!
I have the Mr. RC Sound system in all my prop warbirds and a couple Bi-Planes but haven't tried it in any of the EDF's and haven't tried the Model Sounds system. The Mr. RC system sounds great on the ground and while taxiing and flying close to the pits, but when it is outbound on the downwind a bit out there, it's not that great (but what do you expect). Of course if there's a gas or turbine bird flying at the same time, forget it. It seems to have the most "impact" on spectators at start up, take-off, flying along the runway, landing and shut down. When you get a chance, can you post a photo of where you put the speakers (or transducers or whatever they use) and control board in your F-16? Is it running on it's own small LiPo or off the main battery? Can't wait to see/hear a video of the system in your F-16.
. After trying it, I have to "eat my words" though. It CG'd just fine, just barely fit with no modifications and I could hardly tell the difference in flight, it still took off of grass in the same distance and had plenty of vertical, even though it weighed an additional 70 g at 899 g. And gave me an additional 1 minute or more over the RT 5500. The actual C is just barely below the RT and HRB (100c my rear), but at $179 per battery, that's an expensive extra 60 seconds ($3 bucks a second-would like to get a job that pays that)! Tried it in my SU-30, but it did not do well there, vertical was a struggle, although take-off was fine, but had to use more throttle to keep it cruising and in the end added only about 15-20 seconds of struggling flight time.
