Thanks Ryan. 75mm wide is plenty wide enough and I note that the dimensions given are those immediately aft of the board so presumably the height will get larger as you move back in the battery bay.
But having pre-ordered I am now a little concerned that my 5000 mAh LIPO's that are around 52mm high will fit okay. This is 6-7mm higher than the new 5000mAh Admirals that are smaller in cross section than most LIPO's, so I have my fingers crossed that there is a little more space available 'under the hood' to accommodate slightly larger LIPO's like mine.
